Introduction: How to Open a Door
Doors can close the passageway from one room to another or from one room to outside. They can help with privacy and isolation from outside things like bugs and allergens. In this tutorial, I will teach you how to open a door.
Step 1: Locate Desired Door
First you need to locate a door that you would like to open and make sure that it is currently closed. Trying to open an already open door can look a bit strange.
Step 2: Locate Door Handle or Knob
Locate the handle or knob on said door. This is what is used to open a door.
Step 3: Turn Knob or Handle and Pull or Push
Grab hold of said handle or knob and turn it around 90 degrees either clockwise or counter-clockwise and either pull or push. If you pull and nothing happens, then that means that the door opens away from you. So go ahead and push while still holding the knob or handle turned around 90 degrees. After you have opened the door a sufficient amount to walk through, you can let go of the handle and walk through the doorway.
There you go! You have successfully opened a door!
