Introduction: How to Pick Locks
A quick guide on how to pick locks easily
WARNING THIS IS Illegal
Step 1: Apperatus
First you need:
Metal hair clips
Mechanic's pins (these work best) or a fine screwdriver (flat)
Screwdriver Flat head
Pliers
Head torch or flash light (optional to find the pins)
Metal hair clips
Pliers
Step 2: Apparatus Assembly
Now once you got them together you need to change their shape so it fits it the lock
First get the mechanic's pin and with a screwdriver bend it in to a 90 degrees angle
To look like the one in the picture below
Now the hair clip, on the end of the hair clip there is a small piece of wax or plastic you need to take it off with the screwdriver then flatten it out and that is the apparatus finished.
Step 3: Breaking in Training
Now you need how to use the instruments;
The pin is called a torque wrench and it is placed at the bottom of the lock.and you turn it clock wise but not to hard as the wrench can bend and snap rendering getting useless.
Now get the Hair clip and with the flat end put it in at the top where the pins are (use picture below) now push the pic above the tumbler but don't worry as soon as the pis go above the tumbler they stay there as there is pressure from you turn the torque wrench.
WARNING DO NOT TRY ON ANYONE'S PROPERTY AS THIS IS ONLY EDUCATIONAL
