Introduction: How to Remove Jamberry Nail Wraps
In my last ible I showed how to apply Jamberry nail shields. In this one, I'll be showing how to take them off!
Step 1: Things You Need
-nail polish remover/ acetone/ rubbing alcohol
-cotton swab/ pad/ ball
Or
-alcohol wipe
Or
-alcohol wipe
Step 2: "Break" the Seal
If your Jams were properly bonded, then they most likely would have a pretty good seal. In order to remove them you would need to "break" the seal. All you will be doing is gently lifting the very edge of one side of your wrap.
Step 3: Wipe Away!
My preferred method of removal is to use acetone and a cotton swab. All that is needed to remove the Jamberry nail wrap is to get the soaked item underneath the edge of the wrap, allowing the acetone on it to get under the wrap. This will break down the adhesive and cause the wrap to slide effortlessly off the nail bed!
Step 4: Repeat on All Fingers
I do each nail individually, but you could do it however you like. I know when I do my toes I break the seal on all my toes before moving on the next step, simply because my toe nails are so tiny.
Step 5: Apply New Jams!!
My favorite part about this method is that by using acetone or alcohol you are prepping your nail for new Jams! I hope you have enjoyed my ible! If you would like to try Jamberry send me an email at fisk.paige1@outlook.com or head on over to my website www.pf14.jamberrynails.net to contact me there, or even to place an order if you'd like! Comment below (or email) any questions you may have, and subscribe if you'd like to see more Jamberry or nail art related ible's! Thank you so much for checking this out, and I hope to bring you more soon! <3
