Introduction: How to Replace a GBC Cartridge Battery
Does Your GBC Game Not Save? Do You Want It To Save?
If Yes, Read This.
IF YOU DO THIS, I AM NOT RESPONSIBLE FOR DAMAGE!
What You Need:
2025 Or 2032 Battery (2032 Is Longer Lasting)
Tool To Open Screw
Soldering Iron
Soldier
Multimeter(OPTIONAL)
Wire
Electrical Tape
Step 1: Open the Cartridge
Use Pliers,Screwdriver,Tweezers Or Anything That Will Open The Tamper-Proof Screw
Then Slide The Cartridge Open
Step 2: Test the Battery
BEFORE You De-Soldier The Battery, Test It With A Multimeter. Full Battery Should Be 3.0 Volts
IF BATTERY IS GOOD, DO NOT CONTINUE
NEXT STEP IS RISKY!
NEXT STEP IS RISKY!
Step 3: De-Soldier the Battery
Just De-Soldier The 2 Points That Are Marked In The Image
Should End Up Like The Image
Step 4: Soldier Wires
Soldier 2 wires to the points shown in the image
Attach Piece Of Tape As Shown
READ THE IMAGE NOTES (yellow boxes)
Careful! Soldering Irons Are Hot!
Step 5: Insert and Tape Battery
NEGATIVE SIDE UP
Step 6: Close Up
If It Doesn't Fit, Try Again
Slide the cover back on
If You Want, Reinstall Screw
