Introduction: How to Solve the Rubiks Cube
Step 1: Know the Moves
R=right face
L=left face
U=up face
D=down face
F=front face
B=back face
Step 2: Solve the White Cross
Get them in line with their correct centers also
Step 3: Put the Correct Corners in Place
Just put the white corners in their correct position. Usually I use the saying down bottom up pops the corner up and as long as the corner is in the right position it will work.
Step 4: Solve the Middle Layer
You will need to know the placement of the piece. First you get the piece you need to match the color that it is then if the other color on that piece needs to move down one layer to the right you will use this algorithm: U R Ui Ri Ui Fi U F
If the piece you need needs to go down one layer and to the left then use this algorithm: Ui Li U L U F Ui Fi
Step 5: Solve the Yellow Cross on Top
There are three different states your cube could be in right now. If you have one yellow piece in the middle and no other use this algorithm: F U R Ui Ri Fi
If your cube has what looks like hands on a clock use this algorithm: F U R Ui Ri Fi
If your cube has a line make it horizontal and do this algorithm: F R U Ri Ui Fi
Step 6: Get All Yellow on Top
Perform this algorithm several times and you will get all yellow on top: R U Ri U R U U Ri
Step 7: Get All the Yellow Corners in Place
Do this algorithm several times until your cube looks like mine in the picture: Ri F Ri B B R Fi Ri B B R R Ui
Step 8: Finish Solving It
Perform this algorithm several times and it will be solved:F F Ui L Ri F F Li R Ui F F
