Introduction: How to Start a Car
Cars are a very popular mode of transportation. They come in all shapes and sizes. But before driving a car, one should learn how to start it. That is what I will be showing you in this tutorial.
Step 1: Acquire Car
If you do not already have a car, you can find one at car a dealership and car dealerships exist pretty much all around the world.
Step 2: Determine Key to Start Car
After you acquire a car, you should've been given a key to start said car. If your keys are mixed up and you have no way of distinguishing the desired key, you may need to try all of them in the next step until you have succeeded. If you don't have a key, you can have a locksmith make one for you from the lock in your car but that can be quite costly.
Step 3: Gain Entry to Vehicle
If the doors to the vehicle are locked, insert the key to (preferably) the drivers side door lock, and turn the key either clockwise or counterclockwise; whichever unlocks the door for you.
Step 4: Insert Key Into Ignition
Enter vehicle and insert key into ignition.
Step 5: Turn Key Clockwise Until Engine Starts to Turn
Turn key clockwise until you hear the starter motor start to spin. You will easily be able to tell when this happens as the engine starts making noise and the car starts to shake. Usually after a few seconds, the sound the engine is making will greatly increase in pitch and start to smooth out. When this happens, let go of the key to turn off the starter motor. If the engine stalls, repeat the process. If it doesn't, then you are successful.
NOTE: Some newer cars just require you to enter the key into the ignition and then all you have to do is press a button. If this is the case, do so.
Also, if the car fails to start or the starter motor doesn't move at all, the car might have a dead battery or may be out of gas. If these aren't the cases, then your car may require a mechanic.
