Introduction: How to Terminate Coax Cable
Read the instructions, or watch our video to easily learn how to terminate a Coax TV cable in just a few steps!
First, you'll need these items:
- Coax Cable you'd like to terminate
- Cable Stripper
- F-Type Connector
- Compression Tool
Step 1:
Take your cable stripper and place it onto the cable, leaving a small amount of the cable peaking out on the other end.
Step 2:
Next, spin the cable stripper around the cable, several times, until you are sure it has cut through. Spin in one direction first, then spin in the other direction.
Step 3:
After the cable stripper has made a clean cut, pull off the end. You may have trouble pulling off the back portion. If this is the case, use a Needle Nose Plier to grab that last bit and pull it off.
Step 4:
Next you'll take the F-Type connector and insert it onto the end of the cable.
Step 5:
Inserting the F-Type connector may take some effort to make sure there is a firm connection. Press down with force and twist to make sure it's properly on.
Step 6:
Your goal is to have the end of the copper cable approximately flush with the end of the F-Type Connector.
Step 7:
Next take your compression tool and insert the cable with the F-Type Connector into the tool.
Step 8:
Squeeze the handle several times.
Step 9:
Last, make sure that the connector is firmly attached to the cable by pulling on the end. If it passes your test, you have successfully Terminated a Coax cable!
