Introduction: How Can You Make Your Balloon-Sat ?
When we started we thought it would be prepared to contest IREC’10 Rocket Competition tests are going to do the most important factor for us. We thought that methods to try electronic system such as High-altitude ballon, Civil aircraft, microlight aircraft or multicopter to leave satellite model.
The easiest way to use Hellium balloon !
Step 1: List of Material
Electronics
CanSat Main Board
Arduino Nano
10Dof IMU
Real Time Clock
SparkFun Venus GPS Module
Li-po battary 3 cell
Xbee S2b 2.4 GHz Communication Module
Action Camera ( Hacked )
Voltage Regulator for action camera
Directional antenna for ground station
Mechanics
Parachute 50 cm in diameter
Pvc Container
Metal Gear Servo motor for seperation system
Software
Arduino IDE
XCTU Software for ground station
Step 2: Make It
Lets make a Ballon-Sat,
Firstly I assembled electronic parts for cansat main board then All programs tested separately.
First test : Does the SD card is working correctly ? if it is Yes and next test
Second test : Does the IMU is working correctly ? if it is Yes and next test
Third test : Does the GPS is working correctly ? Sure I was in open air. GPS looked sky. if it is Yes and next test
Fourth test : Does the Altitude sensors is working correctly ?
Fifth test : Does the Communication is working correctly ? I was sure send a data and recieved data on my ground station.
We can solve a lot of problems with this method. If everything is correct, I could begin to merge all program.
Step 3: Make It
Time is assemble the Balloon-Sat Structure. So We used PVC box which is more stronger and light than other metals.
We used servo motor for seperation system. System locked to balloon specific angels of servo motor and seperation from ballon others angel of servo motor.
The specifics of this step will depend on how is precise the altitude sensors. We test again Altitude sensors with servo motor. For instance, If our Balloon-Sat at 10 meters above the sea level, main board turn the 90 degrees servo motors rotor. Balloon-sat attached the hellium balloon. If our balloon-Sat at 15 meters abouve the sea level, main board turn the 180 degrees servo motors and balloon-sat seperating from the hellium balloon. We tested such a case at least 10 times. The last time we checked Electronics and software when all construction is completed.
We modifed the action camera because its battery died and we used external battery for the survival of the camera :). We used external voltage divider to clearly 5 voltage.
Step 4: Use It
The balloon-Sat was fully assembled. We were ready to Fly, We were waiting weather conditions.We were sure that all electronics working and communcation was ready. We were waiting GPS connect to satellite.
Everything was OKAY. Turned the main board on. We realeased the balloon-Sat to the sky. Our goal was to perform separation of 500 meters. We were not sure that we will find again :). We wrote on our contact information. We sent him an obscurity.
Thank you for your time in reading this,
Source :www.foxinspace.com/2015/08/15/how-can-you-make-your-balloon-sat/
