Introduction: How to 3D Print Anything?
3D printing is a new and innovative pattern in which layers and layers are compiled and a finished object is prepared with the help of a 3D printer. A CAD file is required and it’s all done with the help of filament and accessories. To perform the printer, let it preheat well. And voila, your printed object is ready when you give command to print. 3D printing has its application in various industries like medical, construction and food and beverage industry.
Step 1: Identify the Printer to Be Used.
Whether you are using it for domestic use or at home or to teach others or make a DIY project. Solve the purpose first. There are printers like Creality, Flashforge, Tevo, and Wanhao. Make sure it's cost-effective.
Step 2: Introduce the CAD Software Where You Are Going to Be Drawing Your Sketches In.
Use a tool such as Tinkercad, Google Sketchup, or Blender. Put it through the file preparation software for the printing of your file.
Step 3: Export the Model As a STL File to Your Laptop
From digital to a physical object, it will take not much time. It will take a few hours. Make an STL file which will finally go into the pre-heated printer to print and give you the object or toy for your children. A coffee mug can also be 3D printed.
Step 4: Put the Plastic Filament Spool at the Back of the 3D Printer, and Put the Filament Into the Heating Block.
Remember to preheat the printer before you import your STL file for the heating process takes only 10 minutes. Put the filament and set your printer according to the size and specification of the thing that you want to print.
Step 5: Choose the Related Setting on the Printer (USB Cable or Card Reader)
Whether it’s for domestic use or industrial use, a 3D printer will let you print the object of your choice after you connect the card reader or USB cable.
Step 6: Choose the File of Your Model That You Are Printing. and Give the Command to Print.
When designing your stuff, use dimensions that your printer is able to print. If you are not able to sketch within the printer's maximum specifications, design the part into various smaller parts.
Step 7: Allow Your Printed Thing to Cool for About a Minute Before Removing It From the Printer.
Finally, your object in your hands. Make it for home decor or as a project or for your kids, it’s up to you now! It’s ready to be used as an object.
