Introduction: How to 5d Diamond Paint
Dimomd paintings are for me a way to relax. But, sometimes the directions can make it sound so complicated. This is the directions explained to easily understand.
Diamond painting kit:
Diamond dots chart
Dots pre sorted
Wax
Craft tray
Stick to put the dots on
Bags
Not included:
Scissors
Duct or masking tape
Diamond dots chart
Dots pre sorted
Wax
Craft tray
Bags
Not included:
Scissors
Step 1: Setting Up the Beads
First, you want to take your stick and stick it into the wax. This helps the beads stick. Next, pick your color you want to start with. I normally start at the bottom. Open it and pour it into the tray to hold it while you put it onto your painting.
Step 2: Putting the Beads On
Peel back a little bit of the plastic on top after you pick your color. There is normally a key at the side that shows you your symbols and numbers. Use the stick and grab the curved side of the bead. Use the stick and place it on its proper spot on the painting. Continue this until you finish the painting.
Step 3: Closing the Bags
Most diamond painting come with a few bags. But you will most likely run out. So I have found that if you use tape, it stays closed
