Introduction: How to Add JS and CSS to Drupal 8?
In a recent update made by Drupal 8, they have changed the way the asset libraries for both JS and CSS are attached to the theme. You will need to think of adopting these strategies for a variety of scenarios. Here are some of the widely thought of strategies that you can use to add JS and CSS libraries to your Drupal 8 application or website.
Global Styles and Scripts
If you want to add the CSS or JS assets through global libraries then here's how you can possibly achieve that.
The name of the global library is global-styling which will help in creating global styles, and it has been declared within the theme_name.libraries.yml. It is also added within the theme_name.info.yml. You can avail this library through the website, as it has been declared as the global library. The theme_name.libraries.yml file will appear as follows
global-styling:
version: VERSION
css:
theme:
css/style.css: {}
Declare the file that you have just created to theme_name.info.yml file
type: theme
core: 8.x
libraries:
- theme_name/global-styling
Next, you need to declare the scripts to the same path
global-scripts:
version: VERSION
js:
js/script.js: {}
Now, add the following libraries
type: theme
core: 8.x
libraries:
- theme_name/global-scripts
Combine both CSS and JS assets into one
global-styles-and-scripts:
version: VERSION
css:
theme:
css/style.css: {}
js:
js/script.js: {}
Deleting or Overriding the Styles in Core
Go to theme_name.info.yml and
stylesheets-remove:
- normalize.css
You can even override the core's stylesheets
Declaring Dependencies
Generally, you won't find any default additional scripts. You can look in the following path to get an idea of the core assets: /core/assets/vendor. Here's how you can declare a dependency in Drupal 8 for your CSS or JS assets
global-scripts:
version: VERSION
js:
js/script.js: {}
dependencies:
- core/jquery
- core/jquery.once
- core/modernizr
Scope of JS File
If you want to change the position of an asset from the header to the footer, you can easily specify the scope and venture to do so. You can specify the scope in theme_name.libraries.yml
js/script.js: { scope: footer }
Specify Media Type
Specify a particular print stylesheet with a media parameter for the theme_name.libraries.yml
css/print.css: { media: print }
Conditional CSS or JS for Old IE Browsers
Specify the IE conditionals by specifying the parameters in theme_name.libraries.yml file
http://yui.yahooapis.com/3.18.1/build/yui/yui-min.... { type: external, browsers: { IE: 'lte IE 8', '!IE': false } }
Deepa is a passionate blogger associated with Semaphore Software. A leading Offshore drupal web development company. She loves sharing information regarding drupal development tips & tricks.
