Introduction: How to Add an Architectural Model Into Context
Introduction: Models are a tool that every architect can use. Importing your model into a site allows them to be imagined with the direct context. Through this method, you will be able to take an image of your model and using photoshop, transport it into anywhere in the world. This will be useful for aspiring architecture students and practicing architects. Use this to WOW clients, professors, and colleagues alike.
Copyright Disclaimer under Section 107 of the copyright act 1976, allowance is made for fair use for purposes such as criticism, comment, news reporting, scholarship, and research. Fair use is a use permitted by copyright statute that might otherwise be infringing. Non-profit, educational or personal use tips the balance in favor of fair use.
To complete this process, you will need the following:
1. A model
2. An image of your model
3. A computer with Adobe Photoshop
4. An image of your intended site
5. Camera
Step 1: Open the Image of Your Model in Photoshop
After you have created your architectural model and taken an image of it, use photoshop to open the image.
Step 2: Cut Around Your Model
Using the Lasso tool, trace around your model to separate it from the background. Cutting the model away, copy it using CTRL or COMMAND + C.
Step 3: Insert the Model Into the Site
After finding an image of your site, open it Photoshop. Using CTRL or COMMAND + V, paste the model into the window. Using CTRL or COMMAND + T, resize and relocate your model to your desired scale and position.
Step 4: Desaturate the Images
For each layer, open the Image button on the top panel and select Adjustments. Then select desaturate. This will effectively desaturate the images making them black and white. Feel free to use further image adjustment tools to adjust the contrast, hue, brightness, and saturation levels.
Step 5: Add Shadows
Using the brush tool with the color black selected, at a low opacity, draw in the shadow on the correct side of the model that correlates to the context. Remember in this step that shadows will be stronger where the sun is less apparent and fade to lightness as the sun overtakes the casted area.
Step 6: Crop the Image
Select the Crop tool and crop the image to your desired size. Reducing the overall cropped area creates a focal point on your model and you can direct the attention of the viewer.
Step 7: Final Product
Export the final image and save. The final image is a cohesive visualization of your model into your selected site and context.
Step 8: Putting It All Together
Here is a time-lapse that quickly shows all of the steps brought together.
