How to Automate Your Room With Arduino? ENC28j60 Android & IOS Final Part
Intro: How to Automate Your Room With Arduino? ENC28j60 Android & IOS Final Part
Hey all of you! i've been working on automating my room, and i finally got it after a hard coding and many tries, and i'm glad to share with you my achievements.
This project consist on a system arduino controlled, that let you control whatever you want remotelly from any device that can get connected to internet, by typing an iP that has a Web app that i designed on the arduino code for my need.
STEP 1: Demostration Video
Here you can see some tips, the process, and the demostration of the system working perfectly
STEP 2: Materials You Need:
1-Arduino nano
2-ENC28j60 ethernet shield
3-4 Relays
4-2n2222 NPN Transistors
5- 1amp Diodes
6-1k ohm Resistors
7-1x Dual terminal block, 1x triple terminal block
8-PCB board
9-OVC3860 audio bluetooth module
10-2x 3.5mm audio jacks
11-Some wires for conecction
STEP 3: Arduino Code and Electronic Schematic
Here is the circuit diagram and the file on Fritzing and the arduino code designed by me.
STEP 4: Html App, (it's Coded in the Arduino Code)
This is the web app, typed on html. You can modified as much as you want.
STEP 5: If You Want to Do It by a Remote Control (IR)
Here is a video to show you how to comunicate with the arduino.
Just add an IR receiver in the circuit on a free input pin of the arduino and use de library IRremote.
