Introduction: How to Automatically Change the Screen Brightness on Your Lattepanda
Your phone is smart enough to adjust the screen brightness automatically. But most of the computers don't have this sweet function. In order to make my computer more humanized, I write an easy demo to realize this function. Hope you like it! If you have any questions, please let me know:-)
Step 1: What You Need
Hardware list:
Software list:
Note:
LattePanda is a low cost regular Windows computer, it also includes an Arduino co-processor, which means it can be used to control and sense the physical world when you add sensors and actuators.
If you don't have the LattePanda, you can plug in Leonardo to your computer instead.
Step 2: Simple Demo
First of all, let's try to use an easy way to change the screen brightness like the gif picture show above. You just need to use your computer.
Step 3: Simple Demo——step1:
Open the Visual Studio and create a new Windows Forms Application.
Step 4: Simple Demo——step2:
In 'ToolBox' dialog, drag the 'Button' and 'Trackbar' to the form.
Step 5: Simple Demo——step3:
Copy the following code.Start.
Drag the bar and press the button.
See what will happen.
<p>using System;<br>using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Runtime.InteropServices;</p><p>namespace 滑条控制屏幕亮度
public partial class Form1 : Form
[DllImport("gdi32.dll")]
private unsafe static extern bool SetDeviceGammaRamp(Int32 hdc, void* ramp);</p><p> private static bool initialized = false;
private static Int32 hdc;
private static int a;
public Form1()
InitializeComponent();</p><p> }
private static void InitializeClass()
if (initialized)
return;</p><p> //Get the hardware device context of the screen, we can do
//this by getting the graphics object of null (IntPtr.Zero)
//then getting the HDC and converting that to an Int32.
hdc = Graphics.FromHwnd(IntPtr.Zero).GetHdc().ToInt32();</p><p> initialized = true;
public static unsafe bool SetBrightness(int brightness)
InitializeClass();
if (brightness > 255)
brightness = 255;</p><p> if (brightness < 0)
brightness = 0;</p><p> short* gArray = stackalloc short[3 * 256];
short* idx = gArray;</p><p> for (int j = 0; j < 3; j++)
for (int i = 0; i < 256; i++)
int arrayVal = i * (brightness + 128);</p><p> if (arrayVal > 65535)
arrayVal = 65535;</p><p> *idx = (short)arrayVal;
idx++;
}</p><p> //For some reason, this always returns false?
bool retVal = SetDeviceGammaRamp(hdc, gArray);</p><p> //Memory allocated through stackalloc is automatically free'd
//by the CLR.</p><p> return retVal;
}</p><p> private void trackBar1_Scroll(object sender, EventArgs e)
}</p><p> private void button1_Click(object sender, EventArgs e)
a = trackBar1.Value;
SetBrightness(a);
}</p>Step 6: Screen Brightness Auto Control Demo
If you have the Lattepanda, that's perfect. If you don't, you can use Arduino UNO or Lenardo board and connect it to your computer.
using System;
using System.Linq;
using System.Text;
using System.Threading;
using LattePanda.Firmata;
namespace screenbrightnesscontrol
class Program
if (initialized)
return;
InitializeClass();
brightness = 255;
if (brightness < 0)
brightness = 0;
arrayVal = 65535;
idx++;
//by the CLR.
return retVal;
static Arduino arduino = new Arduino();
static void Main(string[] args)
arduino.pinMode(0, Arduino.PWM);
SetBrightness(70);
int flag1 = 0;
int flag2 = 1;
int flag3 = 0;
int j;
while (true)
int a=arduino.analogRead(0);
Console.WriteLine(a);
if (a >= 100)
if (flag1 == 1)
for (j = 0; j <= 140; j+=4)
Console.WriteLine(j);
SetBrightness(j);
if(flag2==1)
for(j=70;j<=140;j+=4)
SetBrightness(j);
flag1 = 0;
flag2 = 0;
flag3 = 1;
if((a > 25)&& (a < 100))
if (flag3 == 1)
for (j = 140; j >= 70; j-=4)
SetBrightness(j);
Thread.Sleep(1);
if(flag1==1)
for (j = 0; j <= 70; j+=4)
SetBrightness(j);
flag1 = 0;
flag2 = 1;
flag3 = 0;
if(a<25)
if(flag2==1)
for(j=70;j>=0;j-=4)
SetBrightness(j);
if (flag3 == 1)
for (j = 140; j >= 0; j-=4)
SetBrightness(j);
flag1 = 1;
flag2 = 0;
flag3 = 0;
Thread.Sleep(1000);
}Try to shine your flashlight over the sensor and see what will happen. The screen brightness will change according to the light intensity.
Every second, the computer will read the data from the sensor and then judge the light intensity. I set 3 levels of screen brightness in my code.The screen will become brighter when the light intensity is high.
Step 7: Screen Brightness Auto Control Demo——Step1:
Open Arduino IDE and select the “StandardFirmata” ( File-Examples-firmata-StandardFirmata ).
Upload the sketch.
Step 8: Screen Brightness Auto Control Demo——Step2:
Connect the Ambient Light Sensor directly into pin A0.
Step 9: Screen Brightness Auto Control Demo——Step3:
Open Visual Studio and create a new Console Application.
Step 10: Screen Brightness Auto Control Demo——Step4:
Download the LattePanda.Firmata class library.
Add the downloaded class library to your project. Open your Solution Explorer and right-click in the blank area, then add existing item→select arduino.cs (Get more help here).
Step 11: Screen Brightness Auto Control Demo——Step5:
Copy the following code, press Start.
using System.Linq;
using System.Text;
class Program
if (initialized)
return;
InitializeClass();
brightness = 255;
if (brightness < 0)
brightness = 0;
arrayVal = 65535;
idx++;
//by the CLR.
return retVal;
SetBrightness(70);
int flag1 = 0;
int flag2 = 1;
int flag3 = 0;
int j;
while (true)
if (a >= 100)
if (flag1 == 1)
SetBrightness(j);
if(flag2==1)
SetBrightness(j);
flag1 = 0;
flag2 = 0;
flag3 = 1;
if (flag3 == 1)
SetBrightness(j);
Thread.Sleep(1);
if(flag1==1)
SetBrightness(j);
flag1 = 0;
flag2 = 1;
flag3 = 0;
if(a<25)
if(flag2==1)
for(j=70;j>=0;j-=4)
SetBrightness(j);
if (flag3 == 1)
SetBrightness(j);
flag1 = 1;
flag2 = 0;
flag3 = 0;
Thread.Sleep(1000);
}</p>Try to shine your flashlight over the sensor and see what will happen. The screen brightness will change according to the light intensity.
Step 12: Problems You May Meet
Step 13: Solution
To use unsafe code blocks, the project has to be compiled with the /unsafe switch on.
Open the properties for the project, go to the Build tab and check the Allow unsafe code checkbox.
Step 14: End
These two demo show how to control your computer screen brightness. Hope you like it. Although this function has already existed in your computer, I'd like to make a new one by myself. If you have any question, please let me know. Enjoy!
THANK YOU VIEWING THIS INSTRUCTABLE
