Introduction: How to Backup Original Firmware of Esp8266EX or Esp-01
Why ? backup of original firmware is important.
simplest ans is = original is original
In this tutorial I will show you how to backup original firmware of esp8266ex.
The ESP8266EX is a low-cost Wi-Fi microchip with full TCP/IP stack and microcontroller capability produced by manufacturer Espressif Systems in Shanghai, China.
Step 1: Hardware Required
Hardware
1. ESP8266EX or ESP8266-01
2. FTDIModule which supports 3.3 v Output
3. Breadboard
4. Jumper wire
I do not advise Arduino. it causes lots of problems
Step 2: Software Required
1. Python 2 or Python 3 its up to you
And do not forget to install (Python Serial Library) for more info and installation process
2 .esptool
3. at last you will need command prompt or terminal
and Software part is done
Step 3: Hardware Connection
FTDI CONNECTION......................ESP8266EX CONNECTION
- FTDI GND..............................................ESP GND + ESP GPIO0
- FTDI RX..................................................ESP TX
- FTDI TX..................................................ESP RX
- FTDI VCC...............................................ESP CH-PD + ESP VCC
Connection part is done now its time to backup
Step 4: Now Command Prompt Part
- copy the esptool to ( C:/ ) Directory
- Open your command prompt
- now follow the commands
cd /
cd esptool
Installation of Esptool
setup.py install
IMPORTANT to correctly set the flash size and flash mode values according to your device.
esptool.py --port COMx flash_id
Firmware backup
esptool.py --port COMx read_flash 0x00000 0x400000 image.bin
Some Extra Commands :
Erase firmware
esptool.py --port COMx erase_flash
Upload firmware
esptool.py --port COMx write_flash -fs 4MB -fm dio 0x0 image.bin
Change the value of x to your COM port x=Port Number ....Example: COM15,COM12
3 People Made This Project!
- shoukat2003 made it!
- rogers2000 made it!
- nsetiaji made it!
8 Comments
8 days ago
Super helpful. Thank you friend. Cheers !
1 year ago
Can i upload this bin file to another esp8266 same module.?
Reply 1 year ago
I upload it to another esp8266.
Reply 1 year ago
Thanks for replying .i will apply ot.
3 years ago
Title: It is Flash. Like the lightning... Flesh is part of a living thing. ;)
Reply 3 years ago
Thanks for corrections
3 years ago
Nice job on your first Instructable :)
Reply 3 years ago
Thanks
