Introduction: How to Build 8x8x8 LED Cube
About: Maker | Developer | Content Creator
An 8x8x8 LED cube is a visual treat with 3D effects and patterns. It works on the concept of Persistence of Vision, a feature of the human eye which tricks our brain in to thinking that an object is present permanently at a place if it appear about 60 times in a second.
Since an 8x8x8 LED Cube consists of, well 8x8x8 = 512 LEDs, we cannot control all these 512 LEDs at once. What we can do is control 64 LEDs at a time at an extremely fast rate and trick our brain as if we were controlling all the 512 LEDs.
This LED Cube will light up any party.
Your friends will be mesmerized by its hypnotic effect as lights dazzle and dance in brilliant patterns.
This cube gives of a warm glow that is pleasant to the eye and will entertain people of all ages .
Though it might be quite a commitment to build, the effort will be worth the wait.
Surprise your friends and family with this incredible art piece, as it will be sure to turn heads.
Don't skip this wonderful electronics project because it offers invaluable opportunities for electronic construction and Arduino coding.
Love automation and smart devices?
πŸ‘‰ Check out IoT Projects with ESP32/ESP8266, sensors, and more:
Arduino Nano
LEDs (5mm) – 512
100Ξ© Resistors
2N2222 NPN Transistors –
74HC574 Octal D Flip-flop –
120-pin IC Socket –
816-pin IC Socket –
1Power ON LED –
15V Power Supply
Male Headers
Female Headers
Connectors with Headers
Connecting Wires
Tools
Stripper
Soldering Iron
Solder Helping Hands
Wire
Cutters/Strippers
Needle Nose Pliers
Vice
Step 1: Video
The following video shows how to build 8x8x8 LED Cube.
Interested in DIY electronics?
πŸ‘‰ Visit my site for 20+ Arduino Projects for students, hobbyists, and engineers:
go for a more creative and amazing projects and tutorial.
Step 2: Test the LEDs
As I’ve already mentioned earlier, we need 512 LEDs.
The first step is to test all the 512 LEDs. You can use a 3V Lithium Cell to test the individual LED.
This step is very important because once you begin soldering the LEDs, it will be difficult to remove them.
They will need to be stable and bright. This step will show you how to separate the faulty ones from the usable ones.
Step 3: Difference Between Diffused and Transparent LED
Step 4: Bend All LED
Start by bending the shorter leg (the cathode) at a 90 degree angle.
Step 5: Building the Layers
Next step is to create the layers. Each layer is made up of 8Γ—8 LED Matrix consisting of 64 LEDs. In order to build the layers, take a Sunboard and make holes at a distance of 2.5CM. Place the LEDs and start soldering all the cathodes together.
Create an 8x8x8 template so you can create the layers.
You will need a MDF board and you will need to drill holes into the MDF wood board to space the LEDs 1/2" apart.
Step 6: Layers
In order to increase the strength of the layer, solder few connecting wires between LEDs.
In addition to acting as support bars, these wires will also short all the cathodes of that particular layer.
Now, test the LEDs once again as replacing a faulty LED will be somewhat easy at this stage.
Once everything is done, put aside the completed layer and continue making seven other layers.
Step 7: Stacking Up Vertical Layers
After completing eight layers, we will now proceed with stacking those layers vertically.
Take a MDF board and mark 64 holes to insert poles for 64 Anode Terminals.
Start soldering layer by layer and use any object like a ruler or even a piece of MDF board to separate the layers.
Step 8:
Finished structure after stacking all the eight layers, will look something like this.
Step 9: Circuit Diagram
The following image shows the complete circuit diagram of the 8x8x8 LED Cube using Arduino Nano.
Step 10: Assemble the Circuit
We have designed circuit for this Project:
74HC574 IC’s that get connected to the Anode rows of the LED cube, Arduino Nano, transistors and power supply components.
Step 11:
Step 12: Final Build and Programming
The final build of the 8x8x8 LED Cube is shown in the image above.
The structure is very strong and all the electronics including the power supply are concealed inside the base
The code is developed based on the work of β€œchr” from Instructables.
There are many codes available in the internet that you can use.
Step 13: CODE
It took nearly 20 working hours to build the 8x8x8 LED Cube (testing LEDs, bending and cutting the LEDs, making 8 LED Layers each consisting of 64 LEDs, straightening wire for adding tensile strength, stacking those layers vertically, designing PCB, etching PCB, soldering components on the PCB, connecting LED Cube to the PCB, dumping the code and testing the output).
