Introduction: How to Build ADJUSTABLE VOLTAGE REGULATOR Using LM317 With SHORT CIRCUIT PROTECTION
DIY | How to build ADJUSTABLE VOLTAGE REGULATOR using LM317 with SHORT CIRCUIT PROTECTION
*** Technical Details***
1. You can adjust the Output voltage from 1.5 volt to 35 volt provided the input voltage is greater then output voltage by at least 2 to 3 volt
2. In the circuit the purpose of the Diode is to protect from short circuits.
a) Diode D1 protects from internal short circuits &
b) Diode D2 protects from external short circuits
Please Don't Forget To Vote For The Contest. Please click the Vote Button on Your Right Hand Top Corner to Vote
***Project Cost***
This project cost me approximately around 3$
Step 1: Things You Need
***Part List***
1. LM317
2. 5K Trimpot
3. 1N4001 - 2
4. Heat Sink
5. Male Header
6. 330 ohm resistor
7. 10uf/25volt Capacitor
8. 0.1uF Ceramic Capacitor
9. PCB Board
10 Soldering Items
Amazon US :
1. LM317 - http://amzn.to/2q6oqsA
2. 5K Trimpot - http://amzn.to/2pWdUJu
3. 1N4001 - http://amzn.to/2pVZskF
4. Heat Sink - http://amzn.to/2q3ItZx
5. Male Header - http://amzn.to/2qEQOGp
Amazon India :
1. LM317 - http://amzn.to/2qIjfkO
2. 5K Trimpot - http://amzn.to/2pWdhiR
3. 1N4001 - http://amzn.to/2r3bdpH
4. Heat Sink - http://amzn.to/2rCcAIC
5. Male Header - http://amzn.to/2qEIgzp
Please Note - All the links provided are affiliated links
Step 2: Circuit Diagram & Finished Images
The Circuit diagram for the voltage regulator is shown in the first image. Construct the circuit according to the circuit diagram.
Note : Don't Forget to connect an Heat Sink to the IC
To adjust the Output voltage fuse the trimmer pot. The Voltage can be adjusted from 1.5 volt to 35 vol & also note the input voltage should always be greater then the output voltage. In the circuit we have used two Diodes. The purpose of the diode is to protect from short circuits.
To watch the working of this circuit you can watch the video posted in the first step
