Introduction: How to Build Stairs | Metal & Wood
About: My name is Omer, I'm an industrial designer and I love to create things. In my free time I work on all kinds of fun projects.
In this project, I am making stairs for my deck which is located at the entrance to my house.
So far, we have been using a temporary wooden pallet as a ramp for access to and from the deck.
It's finally time to create a permanent, stable, and high-quality solution.
Materials:
  • Self drilling screws
  • Wood 14x3 cm
  • Metal Profiles 10x5 cm
  • Cement
  • Sand
  • Gravel
  • Metal bars
  • Galvanized Spray
  • Strong adhesive
Tools:
  • Welding Machine
  • Welding helmet
  • Welding gloves
  • Angle Grinder
  • Clamps
  • Ear protection
  • Impact Drill
  • Leveler
  • 90 degree ruler
  • Measuring tape
  • Wheelbarrow
  • Hoe
  • Bucket
  • Orbital sender
  • Table saw
  • Safety equipment
Step 1: Planning
The planning is based on the architectural design of the house, which defines the heights and widths of the steps, as well as their location.
(This is my sketch :))
Step 2: Iron Frame
I created the iron frame using galvanized iron profiles 10x5 cm with a thickness of 2.65 mm.
I cut the iron profiles to the desired measurements.
I cut at a 45-degree angle to maintain closed profiles along the entire length of the path.
I created three identical frames.
After finishing all welding I cleaned and painted the welds with a protective paint to prevent rust.
For the connections that were not welded (only in the corners), I applied a strong adhesive to prevent water from entering the profiles.
*I did not weld the inner corners to avoid distortions in the metal.
Step 3: Installation
To find the position for the holes in the ground, I placed the profiles above their estimated position and checked with a level and 90 angle tool that I was in the correct position.
I removed the paint from the main iron profile of the deck where I would attach the steps. (That way it will be simpler and easier to weld)
I dug holes approximately 40-50 cm deep.
I placed the profile inside the hole and attached it to the main deck profile using a large clamp.
With a level, I ensured the profile was straight, and with a 90-angle tool, I confirmed it was at a 90-degree angle to the deck, and full weld it.
I also welded two additional iron bars inside the hole in different directions to help grip the profile with concrete.
I repeated the process with the remaining two profiles, leaving the middle one for last. Before the final welding of the middle profile, I checked with an iron profile that all three profiles were in the same plane.
Step 4: Concrete
I mixed cement, yellow sand, and gravel in a bucket (which was too small and not very convenient for mixing, so I switched to a wheelbarrow, which was easier).
 The approximate mixing ratio for each hole was:
  • 2 parts cement
  • 1 part sand
  • 1 part gravel
 I slowly added water while mixing to avoid a too runny mixture.
 I filled the holes with concrete.
Step 5: Wooden Cladding
I made the step surfaces from pine wood planks measuring 14x3 cm.
I attached the planks to the iron using self drilling screws.
I made sure to leave a 5 mm space between each plank and between the planks and the iron - the gaps are important due to the wood's expansion and contraction when exposed to water.
For each step, I attached the first and last plank and then measured the distance between them.
To the missing parts in the middle I cut the desirable size on a table saw to fit the gaps.
Step 6: Finishing
Above the heads of the screws, I applied filler/sealant, after it dried, I sanded off the excess.
I will paint the wood later.
Step 7: Done
Step 8: Support
I will be happy to answer any questions.
Thank you for reading !
You're invited to subscribe to my YouTube channel and follow all of my projects:
https://www.youtube.com/channel/UCkNrUodcQbCM8FDG...
social media:
https://www.instagram.com/kultakala_design_studio/
https://www.facebook.com/kultakaladesign/
https://www.pinterest.com/omerorbach/_created/
Your support is much appreciated!
New projects coming soon!
