Introduction: How to Build a BMX
Before Assembling/ Building a BMX bike it is essential that you work out the total cost of the bike as it usually costs around £1000/$1700, not only that it is important to check all the parts are compatible with the bike.
Step 1: Step 1- Parts
Here is a list of parts that are essential for your BMX:
BMX Frame
Fork
Bearing race
Old Headset Cup (optional)
Grease
Bearing
Top Bearing
Top Cap
Spacer
Gyro Piece
Top Gyro Plate
Stem
Handle Bars
Stem Bolt
Seat & Seat Post
Seat clamp
Micro Adjust (for seat)
Bearings x2
Axel
Washers x2
Axel Nuts x2
Crank Bearing Spacers
Cranks
Sprocket
Crank Arm
Crank Spacers x2
Bolts for Pedals x2
Sprocket Bolt
Complete wheel x2
Socket pegs (optional)
Primo Jewels x2
Washer x2
Socket x2
Chain
Back Sprocket
Chain Tensioners x2
Primo Jewels or Axel Nuts x2
Washer x2
Brake lever x1/2
Brake arms x2
Brake Cable
Tri-Flow
BMX Frame
Fork
Bearing race
Grease
Bearing
Top Bearing
Top Cap
Spacer
Gyro Piece
Top Gyro Plate
Stem
Handle Bars
Stem Bolt
Seat & Seat Post
Seat clamp
Bearings x2
Axel
Washers x2
Axel Nuts x2
Cranks
Sprocket
Crank Arm
Crank Spacers x2
Bolts for Pedals x2
Sprocket Bolt
Complete wheel x2
Primo Jewels x2
Washer x2
Socket x2
Chain
Back Sprocket
Chain Tensioners x2
Washer x2
Brake lever x1/2
Brake arms x2
Brake Cable
Tri-Flow
