Introduction: How to Build a Barbecue Chimney
In this video I'm going to show the construction build process for a metal chimney for the barbecue. For that we will use titanium plates, steel platens, steel angles, weld, stainless steel rivets.
This chimney is stainless, and very durable.
3m2 Stainless steel plate........... 200€
4m Steel angle 30x3.6mm ........ 15€
16m Steel platen 25x3mm...........44€
250x INOX steel rivets 4x12mm...30€
2xHigh temperature silicone......16€
Screws..............................................5€
Welding rods&cutting disks........20€
Step 1: Take Measure From the Barbecue Hole
Take measure from the barbecue hole
Step 2: Adapt the Design to Your Measures
Adapt the design to your measures, here are the measure I used.
Step 3: Cut With a Circular Saw Steel Platen
Cut with a circular saw steel platen
Step 4: Weld Steel Platen an Angles to Mount the Skeleton
Step 5: Paint the Skeleton With High Temperature Resistant Paint
Paint the skeleton with high temperature resistant paint
Step 6: Cut the Stainless Steel Sheets
Cut the stainless steel sheets, draw them in the plate with a pen and cut with the circular saw
Step 7: Drill the Holes
Drill the holes in to the sheets and the skeleton
Step 8: Apply the Fire Proof Silicone
Apply the fire proof silicone in between the skeleton and the sheets
Step 9: Use the Rivets
Place rivet to hold the sheets to the skeleton
Step 10: Put the Chimney on the Bbq
Put the chimney on the bbq and make holes to the basement
Step 11: Apply Fire Proof Silicone
Apply fire proof silicone between the chimney and the bbq
Step 12: Put the Screws
Put the screws
Step 13: Clean the Chimney
Clean the chimney use vinegar
