Introduction: How to Build a Cottage Style Nightstand
Ever want to learn how to build furniture like this cottage style nightstand? Well you’re in luck! Today I’m going to walk you through how to build a high quality custom nightstand!
Check out the video above for the build! If you like it, please subscribe to my YouTube channel and checkout some of my other projects while you're there!
Now, lets start making some dust fly! Grab the plans here and follow along as I walk you through how to make this nightstand build!
➤BESSEY Tools Used: (affiliate)
K Body REVO Parallel Bar Clamp - https://amzn.to/2OxnHzH
Trigger Clamp - https://amzn.to/2S4s0ol
➤Starbond Super Glue: (affiliate) ---Use Code "WSM10" to get 10% off your order!!---
Starbond Medium CA Glue - http://bit.ly/35GnHni
Starbond CA Accelerator - http://bit.ly/35GnHni
➤Materials: (affiliate)
Lumber of choice Glue - https://amzn.to/31woV3v
Dominos 8mm x 100mm - https://amzn.to/31woV3v
Z-Clips (includes screws) - https://amzn.to/31woV3v
Rubio Monocoat (pure) - https://amzn.to/31woV3v
3M pads - https://amzn.to/31woV3v
Accuride Undermount Slide - https://amzn.to/31woV3v
Drawer Pulls - https://amzn.to/31woV3v
Hanger Bolt - https://amzn.to/31woV3v
Threaded Inserts - https://amzn.to/31woV3v
Space Balls - https://amzn.to/31woV3v
Pocket Hole Screws - https://amzn.to/31woV3v
➤Tools: (affiliate)
ISOtunes Pro - https://amzn.to/2So7fkQ
RZ mask M2 - https://amzn.to/2So7fkQ
Table saw (new version) - https://amzn.to/2So7fkQ
Jointer - https://amzn.to/2So7fkQ
Planer - https://amzn.to/2So7fkQ
Dual drum sander (similar to mine)- https://amzn.to/2So7fkQ
Bandsaw - https://amzn.to/2So7fkQ (new version)
Miter saw - https://amzn.to/2So7fkQ
Kreg ACS (track saw) - https://amzn.to/2So7fkQ
Domino XL 700 or 500 - https://amzn.to/2So7fkQ
Wood Lathe - https://amzn.to/2So7fkQ
Turning Chisels - https://amzn.to/2So7fkQ
Outside Calipers - https://amzn.to/2So7fkQ
Sander - https://amzn.to/2So7fkQ
Shop Vac - https://amzn.to/2So7fkQ
Woodpeckers Paolini 6" pocket rule - https://amzn.to/2So7fkQ
Rockler glue roller - https://amzn.to/2So7fkQ Freud glue line rip blade - https://amzn.to/2So7fkQ
Step 1: Rough Cuts & Glue Ups
Like all woodworking projects, this one starts out with rough cutting my stock about 1″ longer than the final lengths needed. This reclaimed chestnut is so dry that it produces tons of dust even with good dust collection running.
The next stop on our milling operations is at the jointer. Here I clean up one face and one edge in preparation for gluing up panels.
At the table saw, I cut the boards to their final widths using my Freud Glue Line Rip blade. I’ve used other ripping blades before glue ups, but this one performs the best in my opinion.
I knock out a series of glue ups using my BESSEY K Body Revo clamps. These parallel clamps provide better even clamping pressure than other parallel clamps I’ve used.
Step 2: Dados and Dominos
The various rails and stiles that are used in this build have dados in them to accept the side and back panels. Here I’m cutting the dado in one of the rails with the help of my GRR-RIP BLOCK. I particularly like these push blocks because they give better control of small pieces like this rail & have tabs that drop down to help push from the end of a work piece.
Next, I set up with my Domino and cut mortises as laid out in my plans. If you don’t have a Domino, this project can be constructed with dowels and/or pocket hole screws. Also, traditional mortise and tenon joinery would be an excellent choice.
Step 3: Assemble Five Panel Sides
The sides of this nightstand are fairly basic. If you’ve ever put together shaker style doors, you won’t have any trouble here. Basically I glued dominos into one of the stiles and then slide two rails into place. After that I slid the center panel into the dados, added the remaining dominos to the rails, and then capped everything off with the remaining stile.
After ensuring that everything is assembled correctly and doubled checking that all of the rails and stiles are flush with one another, I put the assembly in clamps and let it set for a few hours.
Step 4: Assemble Nightstand Case
With both side assemblies complete, I layout and cut for dominos. Check out my make shift work bench vise! If you don’t have a workbench vise large enough, this is a great alternative. Make sure to check out the build video for a little demo on how well this setup works!
After all of the dominos are cut, I glue all of them in place in the side panels first.
I then install all of the remaining rails (with glue) along with the back panel and clamp the case for a few hours. Before I set everything aside, I double check the spacing of the front rails against my plans.
Step 5: Turning Feet for a Custom Nightstand
Using a story stick, I mark out each foot and turn them to the same profile on the lathe. If you’ve never made or used a story stick before, check out my blog post and video!
Next, I drill and install a hanger bolt into each foot so that they can be installed into a corresponding threaded insert, which is installed into the bottom of each stile.
Step 6: How to Build Drawer Boxes Fast
I built these drawer box sides from 1/2″ baltic birch. The first step was to rip the sheet to the widths for the sides, front, and back of my drawer box. For the drawer bottoms, I used 1/4″ baltic birch.
To make assembly as fast as possible, I used a 7mm pocket hole drill in my Kreg Foreman. I drilled 3 holes into the front and back pieces of the middle and bottom drawer box and 2 holes into the front and back pieces of the top drawer box.
After cutting a groove for the drawer bottom, I temporarily hold the box together with my parallel clamps and run in my pocket hole screws.
Step 7: How to Install Undermount Drawer Slides
For this project I used undermount drawer slides. I prefer these because they are hidden when looking at the open drawers from the side and give a very clean appearance.
I installed two plywood strips on each side panel and used a spacer to set the height of each drawer slide.
Step 8: Drawer Front Details and Attachment
I made the trim details for the drawer fronts using strips of matching wood and pre-assembled them as shown below. I used medium thick Starbond glue and accelerator to make these rectangular trim details. For each joint, I first saturated the end grain fibers with glue. Once that glue was cured, I scuffed the surface and then applied a thin layer of CA glue, assembled the parts, and then sprayed accelerator to rapidly cure the CA glue.
To attach the trim to the drawer fronts, I centered the trim and secured it with Starbond medium thick super glue and used the accelerator to quickly cure the glue.
To attach the drawer fronts, I used a stack of playing cards under the left and right corners to center it. I then clamped it in place, pre-drilled, countersunk, and installed two screws from inside the drawer box into the drawer fronts.
Step 9: Making and Securing the Top
With the top planed to thickness and cut to its final size, I used the router table to cut a rabbet on the bottom edge of the front and sides. I used a helical bit to make this cut as they produce less tear out than a standard router bit.
Using Z-clips in slots cut from a biscuit joiner, I attach the top to the nightstand case.
Step 10: Finish of Choice
For these cottage style nightstands, I wanted to go with a low luster finish that has a very smooth touch. I went with Rubio Monocoat 2C in the color Pure. This finish is very easy to apply and you literally can’t make lap lines with this product since it only bonds to raw wood!
Step 11: Go Build One!
Ready to build this high quality nightstand? Grab the table plans here! Be sure to tag your post on instagram with #woodshopmike so we can see how it turned out!
If you want to check out other projects I've done head over to my blog!
To keep up with all of our latest projects and sneak peeks of what's coming up, make sure to follow us on Instagram, YouTube, and Facebook! Also, if you'd like to help support us and fund future projects you can sign up to be a Patron!
As always, if you have any questions, let me know. And until next time, have fun making something!
BESSEY Tools provided me with product and/or monetary compensation as a sponsor of this build. All opinions are my own and are not influenced by the sponsor. All expressed opinions and experiences are my own words. My post complies with the Word Of Mouth Marketing Association (WOMMA) Ethics Code and applicable Federal Trade Commission guidelines.
