How to Build a Dog House
Introduction: How to Build a Dog House
Materials:
- Approx. 250 outdoor screws
- (7) 4'x8' sheets plywood
- (2) 4"x6"x6'
- (1) 4"x4"x12'
- (1) 4"x4"x14'
- (4) 2"x4"x12'
- (1) 2"x4"x8'
- (1) 2"x7"x4'
Tools:
- Power drill
- Saw
- Jigsaw
- Level
Optional:
- Paint
- Paint brushes and/or rollers
Step 1: Cut Pieces to Length
A - (2) 4"x6"x6' [Base]
B - (4) 4"x4"x42" [Base]
C - (1) 4'x6' plywood [Floor]
D - (2) 2"x4"x6' [Base frame]
E - (2) 2"x4"x41" [Base frame]
F - (4) 4"x4"x3' [Corner beams]
G - (2) 2"x4"x6', cut dovetail notches [Top frame]
H - (2) 2"x4"x4', cut dovetail notches [Top frame]
I - (2) 2"x4"x3' [Side wall supports]
J - (2) 38"x6' plywood [Side walls]
K - (1) 38"x4' plywood [Back wall]
L - (6) 2"x4"x27 3/4", cut one 60 degree angle [Rafters]
M - (3) 2"x4"x48, cut two 30 degree angle [Rafters]
N - (2) 3'x6' plywood [Roof]
O - (1) pentagon , 27 3/4"x27 3/4"x2"x2"x4' [Back peak wall]
P - (1) pentagon , 27 3/4"x27 3/4"x40"x4'  [Front wall]
Q - (1) 2"x7"x4' [Face plate]
R - 24"x26" [Door way entrance]
Step 2: Base
1. Lay down two pieces A parallel with each other.
2. Screw four pieces B to the inside of A. Use a level to make the base level.
3. Attach piece C on top of A and B.
4. Frame pieces D and E to outter edge of piece C.
Step 3: Side Walls
1. Attach pieces F to D. Use tri square to make beams perpendicular to floor.
2. Assemble pieces G and H to the corner beams (pieces F).
3. Center pieces I between D and G, then screw into place. Use tri square to make perpendicular to D and G.
4. Attach side walls (J) to pieces F, G, H, and I.
Step 4: Back Wall
Attach back wall (K) to piece F and H.
Step 5: Rafters
1. Assemble pieces L and M together to form a triangle.
2. The 30 degree angles should be placed against pieces L.
3. Pieces L should come together at the 60 degree angles at the top. (Makes three rafters.)
4. Attach all three rafters, spaced out in thirds (front, middle, back), to top frame.
Step 6: Roof
1. Attach pieces N to top of rafters (L). (Forms the roof.)
Step 7: Back Peak Wall
1. Attach piece O to pieces L and M. (Forms a complete back wall from floor to roof.)
Step 8: Front Wall and Entrance
1. Attach front wall (piece P) to pieces F, H, L, and M.
2. Use a jigsaw to cut hole in the front wall as big as you want.
Recommended: 26"x24"
Step 9: Face Plate
1. Attach face plate (Q) to front wall (P), pieces A, and piece B. Use level to make the face plate level accross the bottom of the front of the dog house.
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
    3 Comments
    buirv
    buirv
    12 years ago on Introduction
    What kind of dog are you building this for a Mastiff or a Great Dane?
    zachsmith83
    zachsmith83
    Reply 12 years ago on Introduction
    It is big enough for any dog to fit in and have plenty of space. I built it for my large golden retreiver and siberian husky.
