Introduction: How to Build a Fence.
Have you ever driven out of town and seen a bob wire fence and wonder how they build it? Well today I’ll be going through a step by step process how to build it.
tractor,pounder, wire,post,clips,stretcher,hammer,drill,screws.
Step 1:
The first step is to make sure you mark the areas that you wanna go the opposite direction or where ya wanna put a gate.Be sure the marked areas are lined up with each other so the fence will be straight.
Step 2:
Then next step is to grab a roll of wire and tie the end of the roll to the brace. Then unroll the wire out to a different brace which is lined up to the brace that you tied the wire up to and tie it to there. So, then there would be a guide wire so when you pound your post they will be straight with the brace
Step 3:
Then get a bunch of wood post and metal post.Most people pound three metal post and then one wood all the way down. Then Put them around 6-10 feet from each other.
Step 4:
Then you would have decided how many wires you would want on the fence most people do five or six. From there get however many wires you want on the fence. From There grab one wire at a time and a fence stretcher and connect the stretcher to the wire and connect it on the post and crank it until it gets tight. When it gets tight then grab the wire and wrap it around the brace and tie it to the brace and take the stretcher off. Then do the same thing to every wire. Make sure it is tight enough.
Step 5:
Then get wood staples and nail the wire on the wood post. Then with the metal post you would get metal clips which you would wire them onto the metal post.Then grab wood staples and pound the staples in on the wood post with the wire.Have to make sure that the clips are not to tight with the wire else it might break.
