Introduction: How to Build a Greenhouse - Step by Step Guide
Hello,
I built this garden greenhouse with old windows and recycled door.
Covering with poly. Size 15 ft x 25 ft
Building steps:
Step 1: How to Anchor a Greenhouse to ground
Step 2: Secure the greenhouse base to anchors
Step 3: How to build the side walls structure
Step 4: How to build front and end walls
Step 5: How to build roof trusses for a greenhouse
Step 6: How to install greenhouse plastic
Step 7: Greenhouse base edging idea and exterior finishing work
Step 8: Greenhouse interior finishing
Step 9: How to organize a greenhouse
Step 10: How to build raised beds in a greenhouse
Step 11: How to make greenhouse shelving
Step 12: How to build a greenhouse potting work bench with sink
Watch all videos about this projet here.
Step 1: Step 1: How to Anchor a Greenhouse to Ground
Strong winds can lift a greenhouse. That is why it is necessary to anchor the base of a backyard greenhouse.
Detailed instructions: Read more
Step 2: Step 2: Secure the Greenhouse Base to Anchors
There are different options when building a greenhouse foundation. Cheapest and easy way to build a base or foundation for a greenhouse is to use treated wood beams.
Step 3: Step 3: How to Build the Side Walls Structure
Build greenhouse walls with wood allows customizing of its structure. Must provide to use good materials according the greenhouse covering type.
Detailed instrutions: Read more
Step 4: Step 4: How to Build Front and End Walls
You can use recycled old windows and doors to build greenhouse front and end walls.
Step 5: Step 5: How to Build Roof Trusses for a Greenhouse
How to frame a greenhouse roof? For this project, 2x4 rafters, support beam and board ridge have been used for the construction.
Step 6: Step 6: How to Install Greenhouse Plastic
Using plastic sheet, polyethylene, or poly to enclose a garden greenhouse is the most inexpensive way.
Step 7: Step 7: Greenhouse Base Edging Idea and Exterior Finishing Work
Once the structure of the greenhouse is complete, you can proceed to exterior finishing.
Step 8: Step 8: Greenhouse Interior Finishing
One of the most interesting building steps of a garden greenhouse is undoubtedly its interior design.
Step 9: Step 9: How to Organize a Greenhouse
Be creative to organize your garden greenhouse according to your space and growing needs.
Step 10: Step 10: How to Build Raised Beds in a Greenhouse
Depending the size of your garden greenhouse, it's possible to make raised bed in a greenhouse.
Step 11: Step 11: How to Make Greenhouse Shelving
To organize and support plants in your greenhouse you must build shelves benches or tables.
Step 12: Step 12: How to Build a Greenhouse Potting Work Bench With Sink
A potting work bench with sink is not a luxury in a greenhouse.
