Introduction: How to Build a Mini Boat
How to build a mini boat
To make this project you are going to need some wood, some 2*4 wood and some 2*2, drill bits, a drill, a tape measure, clamp(s), a speed square, a chop saw, 3 screws, and some glasses and earwear for protection.
Step 1: Supplies
To make this project you are going to need some wood, some 2*4 wood, drill bits, a drill, a tape measure, clamp(s), a speed square, a chop saw, 3 screws, and some glasses and earwear for protection.
Step 2: Bottom
For this step you are going to be using 2 screws and some wood. Stack wood on top of each other from smallest to biggest, the size difference should be the same on each side, for mine I made each piece of wood 1 inch bigger than the one on top so 1/2 inch on each side. Then you are going to screw them together with a drill.
Step 3: Hut
To make the Hut that is going to go on top of the boat you are going to get 2 pieces of 2*4, one 3 inches long and one 2 inches long and stack them on top of each other.
Step 4: Assemble
Now you are going to screw the hut onto the base (bottom) of the boat and you will be done. Enjoy :)
