Introduction: How to Build a PC
How to Build a PC
Supplies Needed:
Motherboard
Case
Powersupply
RAM
CPU
Heat Sink
Thermal Paste
Speaker
Step 1:
Place Power supply inside of the case, and arrange the wires as seen fit (align the speaker with the screw holes on the case)
Step 2:
Place the CPU into the CPU socket on the motherboard, and align the triangle on the CPU with the white triangle on the socket
Step 3:
Push down silver latch over CPU and lock it in place with the silver bar
Step 4:
Add a very small amount of thermal paste to the top of the CPU
Step 5:
Place the ram into the slot and push it in until it clicks
Step 6:
Place heat sink over CPU and line up the screws to the holes on the motherboard and screw them in to lock it in place, then plug it in
Step 7:
Place the motherboard into the PC Case and screw it in with the standoff holes (Must line up with IO Shield)
Step 8:
Plug in the 24 Pin connector to the designated spot
Step 9:
Plug in fan with the MOLEX connector
Step 10:
Plug in the SATA connector to the designated spot
Step 11:
Plug in the 8 Pin connector to the designated spot on the motherboard
Step 12:
Plug in Speaker to the correct pins
Step 13:
Plug in the system panel connectors and align up the correct pins to the correct spot
Step 14:
Finish plugging in the cables into the motherboard, and then test if the computer turns on after putting on the side panel
Step 15:
Common Issues:
- Computer wont turn on
- Is the power cable plugged in all the way?
- Is the power switch turned on?
- Is the CPU not put in properly?
- Is there power to the motherboard?
- Wont connect to the monitor
- Is the correct cable connected?
- Is the monitor powered?
- Are the cables fully plugged in?
- RAM Issues
- Is it fully connected on both sides?
- Is it in the right way?
- Is it the right RAM?
