Introduction: How to Build a PowerTech Miniature (dragon Bus)
|________|________|________|________|________|__________|________|_______|__________|_______|______|
Step 1: Gather All of Your Materials
- 4 Wheels
- a battery pack
- 3 batteries
- 4 wires (2 red 2 black) (two already connected to the battery pack)
- 4 cranks (wheel connector)
- 4 metal rods(big)
- 2 metal rods(small)
- 2 motors
- 6 gears
- 1 plastic shell
- 4 metal nuts
- 4 plastic nuts
- 2 left halves of motos casing
- 2 right halves of motos casing
- 3 short rubber tubes
- 5 long rubber tubes
- 11 medium screws (flat tip)
- 5 long screws (flat tip)
- 6 short screws (pointy tip)
.Tools.
([{Screwdriver)]}
Step 2: Assemble the Motors
repeat these steps twice because there are two motors
Step 3: Assembling the Motors (step 1)
Gather The Materials:
6 Total gears (2 small) (2 double sided) (2 normal)
4 Total long metal rods
2 Total short metal rods
6 Total small screws
Materials for one motor
3 Gears (1 small) (1 Double sided) (1 normal)
2 Long metal rods
1 Short metal rod
3 Small screws
Step 4: Assembling the Motors (step 2)
slide two the long metal rods into the lower half of the half of the motors shell. Then insert the small metal rod into the upper half of the half of the motor shell. Now insert the red gears one at a time like the picture shows. repeat for other motor.
Step 5: Assembling the Motors (step 3)
Now insert the motor so the white rod on the motor touches the top red gear.
Step 6: Assembling the Motors (step 4)
Now slide the other half of the motor shell over all of the metal rods so it looks similar to the first image then use the small pointy tip screws and screw them in to hold the two halves of the motor together so that it looks similar to the second image but instead the screws are screwed in.
Step 7: Attach the Motors to Your Base of the Miniature
1. grab your long baseboard and attach the motors so one of them is upside down and the other right side up
Step 8: Insert the Battery Pack and the Plastic Shell
Use tape for the battery pack and little screws and plastic nuts.
Step 9: Attach One Set of Wheels
to attach the wheels attach them to the crank using screws plastic covers and plastic nuts.
Step 10: Finished Product
Here is the link to a video of more or less the same miniatures HERE
Step 11: Measurements
measurements for all the parts
Wheels : diameter 8cm circumference 25.1327412287185cm
Frame length 13cm width 5cm
