Introduction: How to Build a Skill Racing Car With Makeblock
Skill Racing Car is one of the most amusing forms in the MakeblockUltimate Kit. The racing car has cool shape and flexible steering gear. To place the batteries into the racing car, you may race with your partners!
Now, let’s assemble this cool car!
Step 1:
Required materials:
DC Motor-37 12V/50RPM*1
DC Motor-37 Bracket*1
Socket Cap Screw M3x5 *4
Step 2:
Main frame
Required materials:
Beam 0808-184-Blue*2
Beam 0824-96*1
Plate 3x6 *1
Socket Cap Screw M4x14-Button Head*14
Socket Cap Screw M4x22-Button Head*1
Plastic Spacer 4x7x2*2
Step 3:
Fix the beam, the connecting sheet and the motor
with the socket cap screws M4x14 as shown in the Fig.
Step 4:
Lock the socket cap screw M4x22 as shown in the Fig.
Step 5:
Its installation is shown in the Fig.
Step 6:
Steering gear 1
Required materials:
Beam 0808-088-Blue*1
Bracket 3x3*2
Socket Cap Screw M4x14-Button Head*2
Nylon Lock Nut 4mm*2
Step 7:
(Notes: Loosen the nuts and screws. The bracket can be rotated on the beam.)
Step 8:
Steering gear 2
Required materials:
Threaded Shaft 4x39mm*2
Nut 4mm*2:
Step 9:
Steering gear 3
Required materials:
Shaft Connector 4mm*1
Headless Set Screw M3x5*1
D Shaft 4x56mm*1
Shaft collar 4mm*1
Plastic Ring*4
Socket Cap Screw M4x8-Button Head*2
Lock the socket cap screw M4x8 onto the threaded hole of the turnplate as shown in the Fig. (Notes: Be sure to keep the side holes of the bracket and the center hole of the turnplate concentric.) Replace the Shaft Connector marked in the second pic with Plastic Ring and D Shaft.
Step 10:
Steering gear 5
Required materials:
Shaft collar 4mm*1
Headless Set Screw M3x5*2
Take out a headless set screw M3*5 from the
Ultimate Kit, and fix the turnplate onto the motor shaft.
(Notes: The direction of the steering gear and the
position of the U Beam 0808 are close to the front.
Step 11:
DC Motor-25
and bracket
Required materials
DC Motor-25 6V/185RPM*2
DC Motor-25 Bracket*2
Install the motor onto the bracket.
Step 12:
Spoilers
Required materials
Beam 0808-088*2
Bracket 3x3*2
Plate 3x6*2
Socket Cap Screw M4x8-Button Head*8
Step 13:
Trail
Required materials:
The motor and the spoilers assembled in the above steps.
Beam 0824-128*1
Socket Cap Screw M4x8-Button Head*4
Step 14:
Required materials:
Bracket 3x3
Fix the bracket 3x3 and the trail assembled in the
above step onto the frame assembled in the Step 7 with the socket cap screw M4x14 as shown in the Fig. (Notes: The end faces of the trail and the main frame shall be installed at the same plane.
Step 15:
Front Wheel
Required materials:
Timing Pulley 90T*2
Shaft Collar 4mm*2
Flange Bearing 4x8x3mm*4
As shown in the Fig. below, install it onto the
threaded shaft at the head, and fix the front wheel with the shaft sleeve and the headless set screw.
Step 16:
Rear Wheel
Required materials:
Timing Pulley 90T*2
Shaft Connector 4mm2
Socket Cap Screw M4x14-Button Head*4
Fix the timing pulleys 90T onto the turnplate with
the socket cap screws M4x14.
And then install it onto the motor shaft.
(Notes: Fix the headless set screw onto the D face of the motor shaft.)
Step 17:
Tyre
Required materials:
Tyre 68.5x22mm
So, we complete the assembly of the mechanical
parts. Now, we install the motor parts.
Step 18:
Me BaseBoard Bracket
Required materials:
Nylon Stud *4
Base Bracket B*1
Step 19:
Install the Me BaseBoard
Required materials:
Me Orion (Base on Arduino UNO)*1
Nut 4mm*4
Step 20:
Install the Me BaseBoard 2
Required materials:
Take out 2 motor cables from the Ultimate Kit, and
connect them with the motor port of the trail, as shown in the Fig.
And then connect the right motor cable with M1 and
the left motor cable with M2.
Step 21:
Battery Bracket
Required materials:
Nylon Stud *2
Base Bracket B*1
Step 22:
Install the
battery holder
Required materials:
Plastic Rivet R4060*2
6AA Battery Holder*1
Install the battery holder onto the acrylic sheet
and place 6 AA batteries.
Install the battery onto the vehicle with 4 socket
cap screws M4x8, as shown in the Fig.
Step 23:
Motor driver board
Required materials:
Me Dual Motor Driver*1
Install it onto the bracket of the trail.
Step 24:
Install the bluetooth.
Required materials
Me Bluetooth Module (Dual Mode)*1
Step 25:
onto the nylon stud.
And then take out a RJ25 cable.
Connect with the No. 5 port of the Me Bluetooth
Module and the Me BaseBoard respectively.
Step 26:
Steering motor cabling
Take out a RJ25 cable
Connect one end with M1 port of the motor driver
board and another end with No.1 port of the Me BaseBoard.
Step 27:
It is OK now!
Step 28:
To install the Makeblock app onto your mobile phone, you can race with your partners!
Know More About Makeblock:www.makeblock.com/
