Introduction: How to Build a Tensegrity Structure
I wanted to build a tensegrity structure but I cannot find any measurements: here they are...
Step 1: Preparation
you need 6 sticks
- diameter: 6mm
- length: 20cm
- and cut a notch at each ends
In France, look for "tourillon" in any hardware soter, it costs only 0,95€ 1m in 6mm diameter
And you need elastic band.
- 1mm diameter
- make 6 loops
- length: the loop is shorter than the stick (minus 1 ou 2 cm).
The rubber band should be tight on the stick and not fall.
Step 2: Assembly (4 Hands Are Better Than 2)
yes, 4 hands are better than 2!
Follow the steps (picture from http://rainydaymagazine.com/wp/2015/05/18/tensegr...)
Or in the pdf (from www.carolboggs.com)
Step 3: Ta Daaaaa!
here is your finished tensegrity structure :-)
more inspiration?!
