Introduction: How to Build an AC Cobra Replica
I have always dreamt over the cobra replicas so 4 years ago I bit the bullet and chose my kit, I went for a Gardner Douglas Mk4 Euro, lots of reasons why I chose the GD but the main selling point for me was every part of the chassis is new, rather than an old Jag. Anyway, hope you enjoy my brief guide and hopefully inspire a few more cobras on the road.
You don't need a full garage worth of tools. But lots of time and patience.
Step 1: Collecting the Body.
The GD euro build sequence is the body first then the chassis, so off with the trailer to collect the body and start work. A build trolley doesn't just help with moving the body around but also puts the car at a nice height to work on.
Step 2: Flash-lines Flash-lines and More Flash-lines
although the car will be painted, spending the time on the flash-lines now will mean a lot less work in the paint shop. I found scraping with a blade as a negative angle did a good job at removing the bulk and then start sanding, you can see the before and after.
Step 3: Starting to Plan Out the Wiring Loom
The more you think about the wiring in a car the more you realise how many systems there are.
I will be using classic style LED headlights so although still looking classic, will be a bit more than candles in jam jars.
Step 4: More Bodywork Work..
So mainly cutting holes and fitting panels, even after cutting more holes than can count each one is still a nervous task. Measure twice cut once!! I'm not spending too much time on the panel gaps at the moment as it will all be removed for paint, just getting them roughly in the right place.
Step 5: Mocking Out the Dash Board
So I used Inventor to place decals in all the correct places, then printed this out 1:1 so the spacing was correct. Now just to drill all the holes and wrap in the cream leather.
Step 6: ENGINE!!!!!
I started with a 350 Small block Chevy, the whole engine has been stripped down, and only the main block casting retained. Its had the cylinder bores bored to 60 thou, and I will be putting a stoker crank in so it will end up as a 6.3L or 388CDI.
I have sourced a fuel injection compatible intake manifold, Hopefully it will look like classic downdrafts while having the reliability of fuel injection. A mega-squirt ECU will be controlling the fuel and spark.
Step 7: A Bit of CNC With Fusion 360
So I bought a small Denford novamill, ripped out the electronics and got it running GRBL on a arduino. Its proving its worth cutting out stainless plated for lights, cover brackets ect..
Step 8: Chassis Time
Collecting the chassis can be easily done on a roof rack, well withing the load limits, and very little aero drag.
Its then just like a giant lego kit, nice 4 pot ap racing calipers should mean it stops as well as it goes.
Then it was time to hoist the engine in, its a tight fit but after a bit of time its sitting on its mounts.
Step 9: Fluids
Trying to work out the routing of all the coolant pipes, there is just about enough room for the header tank to the the highest piece in the system.
Step 10: 1st Ever Start
A momentous occasion in any car build, the first start. The British weather was against me but noting a tarpaulin wouldn't solve.
Another run with it, still a load of tuning to be don't but the idle is nice now.
1st ever start, idling way too high, and the British weather really not helping me out. Ran it then for a second time. Acceleration enrichment is well off but all in good time.
Step 11: Final Body Prep Before Paint
Again, a bit like the flash-lines, the more effort put in now will show after paint, so take time ans keep working away, I used 400 grit wet and dry. A long a tedious task.
Step 12: A Little Bit of Paint Makes a Big Difference!
Some photos from the paint shop, red primer so stone chips are hopefully less visible. Then Aston martin Diavolo Red main body colour, with BMW storm grey stripes. The stripes are actually tapered so they look parallel from a distance.
Step 13: Reuniting the Body to the Chassis.
Now the body has been fully painted, its back on the chassis to be built back up again.
Step 14: Interior
One by one the pieces of interior are going in, again not rocket science just nice and steady with the carpets, you only have 1 chance to cut them.
Step 15: Finished, I Think
I imagine there will be a lifetime of tinkering, but as far as being road worthy then she is finished. Thank you for taking the time to read all of this and hope you found it useful or just enjoyed it.
