Introduction: How to Build an Easy Compost Bin
Composting is a great recycling mechanism for food scraps. With just a few Maker Pipe connectors, conduit, and mesh wire we can build this easy and affordable compost bin.
- (8) 90 degree connectors
- (2) T connectors
- (5) sticks of 10ft long 3/4" EMT conduit
- Mesh wire
- 3x3 piece of wood
- (5) 3/4" EMT one hole straps
- 7/8" Rubber feet (optional)
Step 1: Measure & Cut
We need 12 pipes for this compost bin. We like to use this metal pipe and tube cutter.
The pipe lengths we need are:
- (4) 4ft pipes
- (9) 3ft pipes
Step 2: Add the 90 Degree Connectors
Measure 12" up and add a 90 degree connector to each 4ft pipe. Then add 90 degree connector to the top of each 4ft pipe facing the same way as the one lower down the pipe.
Step 3: Add the Connecting Pipes
Add the 3ft pipes into the 90's to create the cube structure. Tighten all the hardware fully.
Step 4: Add the Support Pipe
Use the final 3ft pipe and 2 T connectors to add the support pipe from one side to the other on the bottom square.
Step 5: (Optional) Add the Rubber Feet
If you wanted to add the feet like we did, just slide them over the bottom legs.
Step 6: Add the Wood to the Bottom
Secure the wood to the bottom square with the the one hole straps and your screws of choice.
Step 7: Add the Wire
Secure the mesh to the pipes using zip ties or wire. Now you're ready to get composting!
