How to Build an Outdoor Hammock Stand $25
Intro: How to Build an Outdoor Hammock Stand $25
What to see more projects? Check out our YouTube Channel:) https://goo.gl/2s5Mwt
Materials Needed: (affiliate links)
- (7) 2x4x8
- (2) Stainless steel Eye Hooks http://amzn.to/2uCbnWO
- Hammock http://amzn.to/2uJF599
- Timberlok Screws http://amzn.to/2sIZ2eQ
Tools Needed:
- Circular saw: http://amzn.to/2u2TO0y
- Square: http://amzn.to/2u36ODl
- Drill: http://amzn.to/2oIg0aa
STEP 1: Cut Your Boards to Length
Follow the cut diagram above to make all your cuts. All the angles are 25ยบ and be sure to orientate them the correct way.
STEP 2: Assemble the Two Arms
Use the Yellow and Red pieces to create the arms. Sandwich these boards together using some Timberlok screws.
STEP 3: Assemble the Frame
Use the color coded diagram to help with the assembly. Use more 4.5" Timberlok screws.
STEP 4: Add the Feet
Flip over the frame and add your two feet. Be sure to center these to the frame.
STEP 5: Add the Supports
Eye ball a good angle and screw these in place. All that matters is that this section looks good. They just add support to the frame. Be sure to step back and make sure you are doing each side the same.
STEP 6: Add the Eye Screws
Use Stainless steel eye screws here. Pre drill and use a screw driver to screw them in. We used these: http://amzn.to/2u2GdEK
STEP 7: Move Into Place
Find a nice place for your hammock and Relax! Your All DONE!
42 Comments
schumanjim1962 8 months ago
ronanry 6 years ago
as a metric user, i just would like to add some informations ;) (for a future check ;) )
2x4x8 = 2"x4"x8' = 35mm x 90mm x 2.5m
96" = 8' = 2.5m (2.438 to be exact)
48 = 1.22m
36 = 0.914m
12 = 0,3048m
10 = 0.254m
6 = 0.1524m
Pa1963 6 years ago
So, if I go into a European lumber yard looking for a 2x4, what do I ask for?
torvaga 5 years ago
48*98mm is the same as 2*4. You can also choose 36*98mm (1,5*4). It gives you more then enough stiffness, but reduce the total weight alot.
chobbe 10 months ago
torvaga 10 months ago
wbrophy1 6 years ago
torvaga 5 years ago
No, it's not. 2*4 is 48*98mm. 1,5*4 on the other hand is 36*98 (36 if it's planed on both sides)
pdriscoll4 6 years ago
In the UK and Ireland if you ask for a 2x4 they will know exactly what you want. Smaller builders yards will have more knowledgeable (older) staff!
In mainland Europe you just need to work out what you require in mm/cm. 2x4 in metric is 38mm x 89mm like wbrohpy1 has said below but ultimately look for something with the same ratio of 2:1 in a size that suits you.
Woodbrew 6 years ago
Thank you sir:)
IrinaN7 6 years ago
oh, these are super helpful!
srbrosseau 2 years ago
careybear73 2 years ago
mianofr 3 years ago
Jamessully22 3 years ago
ibryanwells 3 years ago
What is the distance between the 2 eye bolts? I want to make sure it's long enough for my hammock.
mianofr 3 years ago
Rembury2020 3 years ago
Bnorville 3 years ago
Seem like US sizes and can't figure it out !
HBofNYC 3 years ago
In the US it's 'buy 7 of the 8'(96") boards'.
96" is 2.438 M
48" is 1.2192 M
36" is .914 M
12" is .304 M
10" is .254 M
6" is .152 M
That said... I didn't realize my hammock was bigger than the prescribed size so I ended up doing what droneshotmnap did and extending the middle board on each arm this morning... I would have rather extended the base with 120" boards...but put in too much time laser engraving a cool logo on it to go run back to lowes/home depot for a 3rd trip this week.
