Introduction: How to Build the Easiest Dining Room Chair Ever
This is a step by step “how to” on a super easy chair build. It doesn’t take expensive tools, and many of the cuts are the same so you can build a lot of them very quickly. If you have issues during the build, be sure to check out my video below to help you throughout the build!
Materials:
1x2” 8ft. 2 pcs
2x2” 8ft. 2 pcs
2x4” 8ft 1 pc
1x10” 36in. 1 pc
3/8” dowel rod 1 pcs
2” pocket screws 16 pcs
1 1/4” pocket screws 3 pcs
2 1/2” sheet rock screws 10 pcs
Step 1: Cut Up Your 2x4 Into 3 Pieces
Cut 2 at 35.75”
Cut 1 at 17”
Then:
Use a table saw to cut the 17” board in half (lengthways)
(These will be your front two legs)
Cut 1 at 17”
Then:
Step 2: Draw the Rear Chair Leg Design Onto the Two 35.75” 2x4s
Mark the middle (lengthways) of the 2x4 near the bottom, middle, and top.
Then make a line across the width of the board 17.75” up from the bottom.
Draw a line down the middle lengthways from the bottom up to that line.
Then from that middle 17.75” point make a line to the top right corner.
Then draw a line from the left side of the 17.75” mark to the top middle mark.
(The video makes this easier to see what is going on)
Step 3: Cut Those Pieces Out With a Circular Saw
This middle section may be easier to cut out with a jigsaw.
Step 4: Let’s Cut Some 1x2s and 2x2s.
We need:
8 1x2s at 14”
5 2x2s at 14”
8 1x2s at 14”
5 2x2s at 14”
Step 5: Drill Pocket Holes in 4 of the 1x2s
We need 2 on each side and one in the center.
The center pocket holes will be used to attach the seat top later.
Step 6: Sand All Your Pieces Down
The rear chair legs may require a little additional sanding
Step 7: Mark the Chair Legs
Put a mark 3” up from the bottom on the front of the rear chair legs
Put another mark 17” up from the bottom on the front of the rear chair legs
Put a mark 3” up from the bottom on the back of the front chair legs
Step 8: Attach the 1x2s to the Legs
Attach two of the 1x2s with pocket holes to the top of the 17” chair leg.
Then attach the other side of those 1x2s flush with the bottom of your 17” mark on the rear chair leg.
I use a 1/4” piece of plywood to offset these 1x2s 1/4” from the outside edge of the chair.
Step 9: Attach One of the 2x2s
Attach one of the 2x2s flush with the top of the 3” marks between the front and rear chair legs.
To attach these, I use my “screw and dowel method”
1. Pre-drill 3/8” hole using a pocket hole drill bit (normal 3/8” bit will work)
2. Attach using 2 1/2” screws
3. Fill holes with 3/8” dowel rod and wood glue
(be sure to watch the video if you need help)
Step 10: Put the Other Side Together
Make sure you build this side the opposite direction as the other side
Step 11: Attach the Two Sides
Attach the 2 sides together using the last two 1x2s with the pocket holes.
These should be attached 17” up from the bottom of the chair legs, just like the other two.
I also offset the The front and back 1x2s 1/4” front the outside edges of the legs.
Step 12: Attach a 2x2 Between the Two 2x2s on the Bottom
Center a 2x2 between the two side 2x2s and attach both sides using wood glue and my screw and dowel method.
Step 13: Cut Two 1x10s to 18”
ALSO: trim 1” off of ONE of the long edges on only ONE of these boards
Step 14: Attach the Long Ends of These Two Boards
Use 3 pocket screws and wood glue to attach these two boards on the long edges to make the seat.
Step 15: Cut Notches Out of the Seat Top
Set the seat top so it overhangs a 1/2” on each side.
Then make a rectangle on the back two corners that matches the chair back in width and length.
(Should be 2” wide x 1.75” deep)
Cut these 2 notches out
Step 16: Attach the Seat Top With Wood Glue and 4 Pocket Screws From the Bottom
Step 17: Assemble the Chair Back
Evenly space the last four 1x2s between the last two 2x2s and attach them with wood glue and finishing nails. The gaps should be somewhere around 1.75”.
Step 18: Attach the Chair Back to the Chair
Attach the chair back to the sides of the chair using my screw and dowel method. The top of the chair back (2x2) should be about 1/2” from the top of the two sides
For the screw and dowel
Step 19: Fill All the 3/8” Holes With a 3/8” Dowel Rod and Trim Them Off
Also, fill all your nail holes with wood filler and sand it down.
Step 20: Your Chair Is Ready to Be Finished the Way You Want It!
Be sure to check out the video if you have issues and follow me on YouTube for more great ideas!
