Introduction: How to Change Differential Fluid | Lexus ISF
About: I love teaching people how to diagnose and to work on their vehicle, also showing them affordable ways to modify their vehicle without breaking the bank.
Freddy from PoorManMods shows you how to change rear differential fluid by using a drill pump and 75w90 gear oil in his 2008 Lexus ISF
Hand pump https://amzn.to/32zpxKn
Drill pump https://amzn.to/3psuPQX
75w90 Gear oil, I prefer to buy it by the gallon as its cheaper per quart: https://amzn.to/3sCaHOm
Step 1: Raise the Car
Safely raise the car using a jack and jack stands, a lift or ramps. Make sure the car is as level as possible so you can accurately put in the proper amount of fluid.
Step 2: Locate the Drain and Fill
Locate the drain and fill plugs on the differential. Before you do anything, break loose the fill plug to make sure you are able to remove it. If the fill plug is stuck or gets stripped out or anything, and you find out after draining the differential you can be in big trouble.
Step 3: Drain the Fluid
Remove the drain plug to drain the fluid, make sure to catch it in a drain pan and dispose of it properly. Then look at the magnetic drain plug, it will be covered in sludge and tiny metal bits, inspect it for large chunks of metal. Clean off the sludge and metal shavings to make sure the drain plug is clean for reinstallation.
Step 4: Remove the Fill Plug
Install the drain plug then remove the fill plug
Step 5: Fill the Differential
Using a drill pump or hand pump fill the differential if the vehicles proper fluid, in this case I used Redline 75w90 which is a great gear oil for most differentials with or without a limited slip.
Place a flashlight behind the bottle of gear oil so you can see how much fluid you are transferring. Fill the differential until fluid starts to dribble out of the fill plug hole.
Step 6: Youre Finished
Once fluid is dribbling out, reinstall the fill plug and tighten it. Then lower the car back onto the ground and youre finished.
