Introduction: How to Change Your Hoodie String
About: Canada's #1 source for online custom designed t-shirts. Head to our website to design your tee now! #jointheherd
In this simple tutorial, we will show you how to swap out a boring plain hoodie string for one with some personality.
  • Hoodie
  • Nylon Para Cord (String)
  • Scissors
  • Pin (Sa
  • Lighter
Step 1: Take the Old String Out
Cut off the knot at one end of the string (if there is one) and remove by pulling the string out from the other side.
Step 2: Measure and Cut
Use the old hoodie string to measure out the length of Para Cord (string) that will be replacing it and cut.
Step 3: Attach Pin and Insert String
Fold one end of the string and put a safety pin through it, this will make inserting and controlling the string easier.
Put the pin inside one of the holes and push it along the hood seam.
When the pin emerges from the other hole even out both ends.
Step 4: Tie Knots
Remove the pin and tie knots in both ends of the new string.
Step 5: Singe Ends
Once both ends of the string have knots, use a lighter to singe the ends so that the won't open.
Step 6: Show Off
Now that your hoodie is complete go and show it off!
If you want to see this tutorial in action then check out the video.
If you need a Custom Hoodie for your project then click the link!
