Introduction: How to Change Your Tire
Step 1: Tools and Materials
1. Car Jack
2. Jack Stands
3. Spare/New Tire
4. Socket Wrench
5. Flat Surface
Step 2: Flat Surface
Step 3: Loosen Lug Nuts
Step 4: Raise Your Car
Depending on the jack you have determines how you raise your car. The one in your trunk is a jack that is a weaker more difficult one to use or the jack I have which has a hand pump. To life you pump it up and down. Using your car jack raise up the damaged side of your car so you can remove the tire. You may refer to your owners manual to find a safe spot to raise your car other wise try to find a solid surface that can't be easily damaged. Make sure you place the jack stands on immediately afterwards. The reason for the stands is so you're not relying on the jack alone. Leave the jack and the stands both up so that the car doesn't fall and get damaged but more importantly doesn't hurt or kill you.
Step 5: Remove the Lug Nuts
Step 6: Changing the Tire
Step 7: Place Lug Nuts On
Now hand screw the nuts as tight as you can while car is still suspended in the air. Don't forget to tighten by going diagonally across from one another.
Step 8: Lowering the Car
Remove the jack stands first and then lower the car with the jack slowly by twisting the handle to the left slowly and gently making sure that your car doesn't come crashing down.
Step 9: Tightening the Lug Nuts
Make sure to stop at a gas station to make sure the new/spare tire has enough air in it, for it may have lost air in the last months being unused.
