Introduction: How to Change Your Voice With a Simple Module
With a voice changer module, you can turn your voice into a baritone or bass, Also, it can turn your voice into a funny child’s voice. It can totally realize real-time output. You can use it to make a mask on Halloween or make an interesting voice changer toy.
Step 1: Prepare Things You Need
voice changer module, 5V USB micro Cable, headphone or speaker
Step 2: Quick Test
When you get the module, please first charge the module.The red light is on and wait for 2-3 seconds. Now, you can speak into microphone, then you will hear the change sound from the headphone.
Step 3: How to Use This Module--Adjust Audio and Amplification
On the back of the circuit board there is an audio player for adjusting potentiometer of large multiples(see the red arrow)
Adjust clockwise to reduce the sound, frequency amplification and sound smaller; Adjust counter clock-wise, increase the magnification factor, the sound becomes louder.
Step 4: Adjust Tone
There is a potentiometer on the front of the circuit board to adjust the tone. (as shown in the picture )
Adjust clockwise to lower the sound Sink, adjust counterclockwise ,
sound becomes shrill. After finished, press the reset button on the left . Only to reset the system and load the latest tone, it will become effective.
Notice : 1、Due to the limited driving capacity of the sound changer itself, it cannot directly push the speaker to make sound. Please use a 3.5mm jack to connect the audio output of the sound changer to the headset or external amplifier sound.
2、When connecting the audio system, please notice that audio system should be far away from the microphone, because of the audio output will also be transmitted into the microphone, which will vibrate, especially if the audio amplification is maximized. At this point, it is necessary to adjust the potentiometer in combination with audio amplification to select the appropriate audio amplification multiple;This problem does not occur when testing with headphones(because the output sound from the headset is not transmitted to the microphone).
3、The volume adjustment mainly depends on the external amplifier sound volume adjustment,audio amplification multiple adjustment potentiometer can only adjust the volume to a certain extent.
A very simple module to change your voice. If you want to get this module just like me, go to Aliexpress
