Introduction: How to Change a Tire
The tires on your vehicle encounter a lot of wear and tear. After some time, it's normal for them to go flat. It's important to know how to change a tire so you can make sure you can safely get to a shop to get your tire replaced or fixed.
- Vehicle supplied or personal jack
- Lug wrench
- Tire
- Optional: torque wrench
Step 1: Park Your Vehicle in a Safe Location
Pull your vehicle somewhere that you can safely change the tire and ensure the parking brake is engaged.
Step 2: Gather Vehicle Maintenance Supplies
Step 3: Place Wheel Block Behind the Wheel
Place a wheel block/chock behind the opposite tire that isn't being changed. Ex: If you're changing the front tire, place the block behind the back wheel so the car doesn't start rolling.
Step 4: Break the Lug Nuts Loose With the Lug Wrench
Step 5: Lift the Corner of the Vehicle With the Jack
See your manufactures' make and model for safe locations to jack your vehicle.
Step 6: Unscrew the Lug Nuts Using the Wrench
Rotate the wrench in a counterclockwise motion until the lug nuts can be removed.
Step 7: Grab the Wheel of the Tire and Remove It
Step 8: Grab the Spare Tire and Place It Onto the Wheel Hub
Step 9: Screw the Lug Nuts Back on Using the Wrench
Screw the lug nuts back on in a clockwise motion.
