Introduction: How to Change the Speed of a Drill Press
Changing the spindle speed for a manual drill press requires physically adjusting belts between pulleys. In this example, we have three pulley sets two belts on a JET drill press. The original speed is 540 and we will be changing it to 1840.
I made this at TechShop Detroit (www.techshop.ws).
Step 1: Unplug the Drill Press
This critical first step is to unplug the drill press. This is to ensure that while your hands are in the dangerous area of spinning pulleys, an accidental machine start does not harm you.
Step 2: Open the Belt Access Panel
The top of the drill press holds a panel that can be flipped open to show the three pulley sets.
Step 3: Loosen the Locking Screws
There are two locking screws on either side of the drill press. Loosen both screws to allow for the motor to be moved. The screws are located beneath the panel on either side.
Step 4: Pull Motor Lever
Pulling the motor lever brings the motor closer to the pulleys and the pulleys closer to each other. Note the difference when the belts are not pulled taut.
Step 5: Determine Belt Position for Desired Speed
To change the speed to 1840 from 540 both belt positions must be changed. The "left" belt will change to a position second from the bottom. The "right" belt will changed to the bottom position.
Step 6: Remove First Belt
The first belt to be removed is the belt on top, which in this case is the "right" belt in the picture. Lift the belt on the pulley set where the pulleys decrease in size from bottom to top. Carefully lift the belt while rotating it on the pulley. Keep your fingers on the outside of the belt to minimize the chance of your fingers getting caught. Once the belt is loose, move it so that it will not be in the way when you remove the "left" belt.
Step 7: Remove Second Belt
Repeating the same process, lift the belt on the pulley set where the pulleys decrease in size from bottom to top. Carefully lift the belt while rotating it on the pulley. Keep your fingers on the outside of the belt to minimize the chance of your fingers getting caught. Once the belt is loose, move it so that it will not be in the way
Step 8: Put First Belt On
In this case, the "right" belt will now be on the bottom position since we are changing to the speed of 1840. Put the belt in the correct position on the pulley set where the pulleys increase in size from bottom to top. Then put the other side of the belt in the correct position on the other pulley set.
Step 9: Put Second Belt On
The "left" belt will now be on the second from the bottom position since we are changing to the speed of 1840. Put the belt in the correct position on the pulley set where the pulleys increase in size from bottom to top. Then put the other side of the belt in the correct position on the other pulley set. Verify that both belts are in the correct position.
Step 10:
Pull the motor lever back in place. The belts should now be taut.
Step 11: Tighten the Locking Screws
Tighten both the locking screws on either side of the drill press to keep the system in place.
Step 12: Close Belt Access Panel
Close the belt access panel.
Step 13: Plug in the Drill Press
Plug the drill press back in... and you're ready to go! The speed has been changed from 540 to 1840.
