Introduction: How to Check and Replace an Engine's Air Filter
Mechanical knowledge required: None-Light
Materials required:
- A screwdriver (medium-sized flathead or Philips head)
- A new air filter
- Optional: A vacuum
An air filter is a crucial component to any car. Every car's engine needs clean air to work properly. Simply put, job of the air filter is to filter the air that goes into the engine from things such as dust particles or pine needles, to ensure that it works properly. Some vehicles have multiple filters or filters located in different spots. We will be looking at the traditional underhood engine air filter. To replace an air filter, you do not need any mechanical knowledge if any, but you should have some familiarity with what an engine bay looks like.
A bad air filter can reduce your engine's life, performance, and gas mileage.
You should check your air filter about every 6 months, or every 3 months if you live in a dusty or dirty environment.
Image sources:
carmodguide.com
www.imakenews.com
Step 1: Open and Prop Up Your Hood
To work in the engine bay of the vehicle, we must open it's hood. The first step in this process is to locate the hood release. This is usually located on the driver's side of the vehicle, on the lower lefthand side. It will usually have a label of a car with it's hood up. Pull the lever until you hear a popping noise. The next step is to open the hood with the hood latch. When you pull the hood release, you will notice a gap between the engine's body and hood. The center of the front of the hood is usually where the hood latch is located. Usually you will feel a piece of metal or plastic. This piece will need to be moved either up, down, left, or right to release the vehicles hood. Use one hand to move the piece and the other to pull up the vehicle's hood. Once the hood is up, you will need to look for the prop rod if the hood does not support itself. This is usually a small rod with a hook. To keep the hood up, lift up the rod up to its hinge and look for a hole at the top of the hood. Place the hook into that hole.
Step 2: Locate the Air Filter Housing
Typically, the air filter housing is located on the driver's side of the vehicle in the engine bay. The housing is usually black in color, boxy in shape, and made of plastic. You will usually see a tube connected to it. This vehicle is a 2001 Pontiac Grand Am GT1.
Step 3: Locate and Undo the Screws or Latches to the Housing
To undo the housing, locate and unscrew the housing's screws. The orientation of the screws or housings may vary with every vehicle. In many cases, air filter housings may use clips or clamps instead of screws. If this is the case, simply undo the clamps or clips.
Step 4: Remove or Reorient the Air Filter Housing
In some cases, you may have to slide a housing away from the tube connected to it to reorient the housing instead of just lifting it up. As mentioned previously, the orientation of the housing may vary.
Step 5: Remove and Inspect the Air Filter
Before you remove the filter, pay attention to and remember its orientation. In some vehicles, the orientation of the air filter matters, while in others, it doesn't. To remove the filter, simply pull it out. Inspect it for any dirt. If it is dirty, you can either vacuum out the dirt or replace the filter. Vacuuming is a good option to get the last bit of life from your filter. To vacuum the filter, simply take a vacuum hose and run it through all of the breaks in the filter. Be sure that no dirt or leaves are left behind. It is also important to inspect the air filter housing. If there is dirt or leaves in the housing, it is a good idea to vacuum it out.
Step 6: Put a Filter Back In
If your filter had a special orientation, put the new or same filter in the way it was before. To find what type of filter your vehicle takes, check your car's manual.
Step 7: Put the Air Filter Housing Back Together
To do this, place the housing back to it's original orientation and line up the screws to the screw holes on the bottom of the housing, then screw the screws back in.If your housing uses clamps or clips, align the housing and reclip it.
Step 8: Drop Your Hood and You're Done!
To drop the hood, lift it up and remove the helping rod. Set the rod back down to where it was and let go of the hood. If your hood has a self-support system, grab the top of the hood and give it downward force until it closes.
Congratulations! You just replaced your engine's air filter!
