Introduction: How to Choose a Knitting Machine
Use this guide to help you choose the perfect knitting machine. Explore various types, from electric and hand-crank models to machines designed for making sweaters and hats.
AB Crafty may earn commission at no cost to you if you purchase through the links
Circular Knitting Machines (Large)
Circular Knitting Machines (Medium)
Circular Knitting Machines (Small)
Flat Knitting Machines
- Silver Reed LK150 Knitting Machine
- Bond America Fashion Knitter
- Bond Incredible Sweater Knitting Machine
- Silver Reed SK280 Knitting Machine
- Brother Knitting Machine - Electroknit KH910
i Cord Knitting Machines
Step 1: What Do You Plan to Create?
When choosing a knitting machine, several factors come into play. Addressing each one will guide you toward the best option for your needs.
Chances are, you’re looking for a knitting machine with a specific project in mind. For me, it was making beanies, along with knitting blanks for dyeing yarn. Maybe you want to make hats, sweaters, or even socks. Thinking about what you’ll make most often can help narrow your options. If you're unsure and want a versatile machine that can handle a variety of projects, that’s okay too!
Step 2: Will You Be Making Large or Small Items?
Consider the size of your projects. If you’re making beanies, will they be for adults or kids? Are you looking to create large blankets, or will scarves be big enough? The scale of your projects will influence the type of machine that suits you best.
Step 3: Do You Need to Knit Intricate Patterns and Designs?
Choosing between a flatbed or circular knitting machine is essential. Flatbed machines are ideal for intricate designs and detailed patterns, offering precision and ease. While circular machines can achieve similar results, they require more effort, much like hand knitting. If efficiency is a priority, a flatbed machine may be the better choice.
Step 4: Would You Prefer an Electric or Hand-crank Knitting Machine?
Some knitting machines come in both electric and hand-crank versions. If you have a strong preference, keep that in mind when shopping. However, your answers to the previous questions might naturally lead you to the best option.
Step 5: Decide on Your Budget
Price is a significant factor, as knitting machines range widely in cost. Higher-end machines, often made of metal, are more durable but can cost several hundred or even over a thousand dollars. More affordable options under $50 are typically made of plastic and may be prone to breaking—I’ve learned this firsthand! (Luckily, a little super glue goes a long way.)
Step 6: Select Your Machine
By considering these factors, you can find the knitting machine that best fits your needs and budget. I've listed the top machines in the "supplies" section above. You can also take a look at my review of all of the knitting machines here.
If you want to keep things simple, here's my choice for each type of machine:
Best Circular Knitting Machine – Sentro 48 Needle
Best Flat Knitting Machine – Silver Reed LK150
Best i-Cord Knitting Machine – Prym Comfort Twist Knitting Mill (Amazon)
Bust Punch Card Knitting Machine – Silver Reed SK280 (eBay)
Best Electric Knitting Machine – Brother Knitting Machine – Electroknit KH910 (eBay)
