Introduction: How to Clean Your Desktop!
This is a guide on how to clean your desktop PC.
If you find yourself wondering why your computer has been a bit noisier than usual, or you are experiencing minor abnormalities with your system, it might be time to give your PC some love.
Before you begin, make sure you have all necessary tools. You will need a can of compressed air, a Phillips screw driver, and either a paper towel or microfiber cloth. A well lit work area and non static surface are also important.
Step 1: Power Off Your System
Power down your PC via the dedicated power button on your systems case, or in the Start menu. Then, unplug the main power cable.
Step 2: Open the Case
To access the inside of your system, remove the side panel. If the panel is made of glass, it can be cleaned with a microfiber cloth and windex.
Step 3: Remove Dust Filters
Unscrew and dismount any dust filters and heat sinks that are attached to the case. Check all sides of your system for panels with detachable dust filters and remove them accordingly.
Step 4: Clean Dust Filters
Attach a nozzle to the top of your can of compressed air, and blow the dust out of the dust filters. If necessary, wipe the surface of the filter with down with a paper towel or microfiber cloth.
Step 5: Dust the Interior
Use your compressed air and microfiber cloth to dust the interior. If you have room, use the cloth to prevent excessive buildup on components with glossy finishes. For tighter spaces, utilize the can of compressed air.
Step 6: Clean the Fans
Use your screwdriver to unscrew your case fans. Then use your cloth to wipe the dust off the blades. If you are outside, feel free to use compressed air.
Step 7: Clean the GPU and Ram
Most modular GPU's consist of a flat surface on the top and a two to three fan units on the bottom. Use the cloth to surface clean the top and side panels of the GPU, and use compressed air on the fans as well as the Ram sticks.
Step 8: Wipe Down Surfaces
Use a damp paper towel or microfiber cloth and surface clean the exterior of your PC.
Step 9: Reassemble and Power On
After putting all components back into place, reattaching the side panel, and plugging the power cable back in, power on your system.
Step 10: Check Task Manager
Finally, open up task manager and check that all of your components appear appropriately.
