Introduction: How to Clean a CPU Fan Without Removing It.
In this video I will show you How to Clean a CPU Fan without Removing it / how to clean cpu fan without compressed air. This method is especially for inexperienced beginners. There are no special tools required for this cleaning method.
If there is a lot of dust in your CPU fan, I recommend removing it and cleaning it. If so, the following video will be useful for you
How to Remove and Clean a CPU Fan - https://youtu.be/AuxFVAP0OHE
Step 1: Things You Need
Things You Need
Toothpicks
Cotton Swabs
Kitchen Tissue Paper
isopropyl alcohol 90% or 90%+
Step 2: Shutdown and Unplug Your Computer
First thing to do is unplug each cable that is plugged in to your computer.
Step 3: Clean the Fan Blades
Clean the fan blades with isopropyl alcohol -soaked tissue paper.
Step 4: Remove Dust From the Heatsink Surface Using a Toothpick.
Remove dust from the heatsink surface using a toothpick.
Step 5: Clean the Remaining Dust Off the Surface With a Cotton Swab.
Clean the remaining dust off the surface with a Cotton Swab.
Step 6: Clean the Bottom of the Heat Sink of Dust As Well.
Clean the bottom of the heat sink of dust as well.
Step 7: Remove the Fan Wire and Clean It Thoroughly.
Remove the fan wire and clean it thoroughly.
Step 8:
Watch the video for more details.
If you like this project perhaps you'll like some of my others. 👇👇👇
https://www.instructables.com/member/Ideaship/instructables/
Thank you.
