Introduction: How to Clean a Shower
Today I am going to teach you how to do a full cleanup of your shower so it looks really nice. This will clean the flooring and this will clean the walls.
Windex Spray Bottle(for glass walls)
Method All purpose spray bottle or Lysol all purpose spray bottle(for regular walls)
Pine-sol bottle
Paper towels
Scrubber/Sponge
2 buckets of water(May need more or less depending on size of shower)
Pine-sol bottle
Paper towels
Scrubber/Sponge
Step 1: Using the Pine-sol Bottle
Ok, first you are going to take the pine-sol bottle and go in your shower. Unscrew the cap of the bottle and just pour small amounts of pine-sol in each area of the shower. Pour some pine-sol in the corners, in the centers, all over the shower, but don’t use a lot of it. Do this in the whole shower.
Step 2: Scrubbing
Now take your sponge/scrub and just scrub the pine-sol together up and down and do this until you have done it all over the shower. When you scrub the pine-sol, it should like a bubbly soap that is white as shown in the picture.
Step 3: Windex
These next two steps will only work if you have glass walls in your shower, if you don’t, don’t worry because the last two steps will be how to clean regular walls in the shower. Now spray the windex on your glass walls, but don’t spray too much. Spray the top, middle, and bottom.
Step 4: Using the Water
Take your buckets of water and pour them over the pine-sol in all areas of the shower. This is the longest part because you have to keep the water in one place for a long time. I recommend spending 10-15 minutes just pouring the water in the shower. The pine-sol will then go in the drain of the shower. You can also just turn on your shower to rinse away the pine-sol.
Step 5: Paper Towels
Now use your paper towels to just wipe the windex away so your glass walls look clean.
Step 6: Method All Purpose Spray Bottle/Lysol All Purpose Spray Bottle
Now if you don’t have glass walls, this will clean those walls. Take your method all purpose spray bottle and use it to spray the walls in the top, middle, and bottom. Don’t spray a lot though.
Step 7: Paper Towels(again)
Now take your paper towels and wipe away the method sprays that you sprayed and your walls will look really nice.
Step 8: Final Product
And now you have a clean shower with clean walls and floors and it smells really good. Thank you for reading my instructable. I hope this helped you and I hope you enjoyed it.
