How to Clear Acne Marks | Dark Scars | Pimple Spots , Get Clean Face Skin
Intro: How to Clear Acne Marks | Dark Scars | Pimple Spots , Get Clean Face Skin
Dark Spots are not disease or serious condition. It is more of a social problem as dark spot skin usually does not look very beautiful.
Remedy No 1.
1.Honey
2.Lemon juice
3.Apple Juice
Process is to first clean your face, then apply a hot water soaked towel on face to open up your face pours. The solution is very water you can apply it on your face with your fingers or you can use soft brust to apply wat evere best work for your face. Once you have applied it all over your face let it sit on there on for 20 mintues. In the meanehile you can do your work. After that you can clean it with washing your face
Remedy no 2
1.Almonds
2.Honey, (Almonds are used to remove dead skin cells from your skin.)
We can make peeling scrubs at home by crushing almonds coarsely and mixing it with mild cream or honey. Apply and massage this scrub in circular motion over the face. Allow it to remain on for about 5 minutes or so and then repeat the massage and then rinse it off thoroughly with cold water. Broken wheat or any other cereal ground coarsely will also serve the purpose instead of almonds. However almonds nourish the skin and can benefit the texture and complexion of the skin with regular use.
Remedy no 3
1.Barlay Floor
2.Yougart
3.Honey
4.Almonds
1.Take 2 tablespoon wheat flour , 2 tablespoon yogurt, 1tablespoon honey and powdered almonds. Mix them together to make a fine paste and apply it on your face for 10 minutes. Rinse with warm water to get an instant sheen.
DIY Hacks and How Tos 8 years ago
Great home remedies
