Introduction: How to Configure and Port Library Files Via Buildroot on the RK3568 Platform
About: Embedded system hardware engineer from Forlinx Embedded
Learn how to configure and port library files using Buildroot on the RK3568 platform. Improve development efficiency for embedded Linux systems with Forlinx.
Step 1:
As a high-performance industrial-grade chip, Rockchip RK3568 adopts a quad-core Cortex-A55 architecture and integrates a GPU and an NPU. It is widely used in edge computing and Internet of Things (IoT) devices. Buildroot is a lightweight build tool designed specifically for embedded systems. It can quickly generate a customized Linux root file system through modular configuration. It is particularly suitable for the hardware features of RK3568, significantly improving development efficiency.
Operation method:
1. Switch to the path OK3568-linux-source/buildroot/output/OK3568/ and execute the command ''make menuconfig'';
How to Configure and Port Library Files via Buildroot on the RK3568 Platform
2. Press the ''/'' key to open the search box and search for relevant library files by keywords. Take adding PYTHON3 as an example;
3. Select options from 1 to 3 according to the search results to jump to the corresponding configuration options. Please use the ''↑'' and ''↓'' keys to turn pages;
Select an option by pressing the ''Y'' key or toggle the selection state by pressing the ''Space'' key.
Choose whether to perform a complete installation according to the needs.
4. Keep selecting ''Exit'' until exit the graphical interface. When prompted to save the configuration, select ''yes'';
5. Recompile Buildroot. Execute the following command in the OK3568-linux-source directory:./build.sh buildroot
6. When prompted whether to overwrite the old.config configuration file, enter ''n''.
7. Rewrite the rootfs.ext2 image generated in OK3568-linux-source/buildroot/output/OK3568/images to the development board. In fact, the rootfs.img generated by a full compilation is created by directly renaming the rootfs.ext2 file. Therefore, using rootfs.ext2 for flashing has the same effect;
8. First, click on the device partition table, then select rootfs.ext2, and click to start the flashing process.
