Introduction: How to Connect KX-040 to Arduino Uno - Different Way!
How To Connect KX-040 To Arduino Uno - Different Way!
Step 1:
Today we will look at how to connect the KX-040 to the Arduino Uno. I'll walk you through it, if another code doesn't work for you and you're still looking for a program that will work for you, this might be the solution! I spent some time on this and finally succeeded and created a working program for this button where there was a lot of interference going on. If you have any questions or additions to your solution, don't forget to write in a comment.
Step 2:
#include <LiquidCrystal_I2C.h>
//button commands only for button and potentiometer
int pin3= 5; //Pin SW
const int pin1 = 2;
const int pin2 = 3;
volatile int statePin1 = 0; // Pin 1 status
volatile int statePin2 = 0; // Pin 2 status
volatile int laststatePin1 = 0;
volatile int laststatePin2 = 0;
volatile unsigned long timePin1 = 0; // Time for pin 1
volatile unsigned long timePin2 = 0; // Time for pin 2
volatile unsigned long lasttimePin1 = 0; // last Time for pin 1
volatile unsigned long lasttimePin2 = 0; // last Time for pin 2
int countererror2;
int countererror1;
int counter = 0;
//button
unsigned long lastButtonPress = 0;
bool buttonState = HIGH;
bool buttoncheck;
LiquidCrystal_I2C lcd(0x27, 16, 2);
void setup() {
Serial.begin(9600);
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.display();
// BUTTON set pin
pinMode(pin3, INPUT_PULLUP);
pinMode(pin1, INPUT);
pinMode(pin2, INPUT);
attachInterrupt(digitalPinToInterrupt(pin1), handlePin1Change, CHANGE);
attachInterrupt(digitalPinToInterrupt(pin2), handlePin2Change, CHANGE);
void handlePin1Change() {
statePin1 = digitalRead(pin1);
timePin1 = millis(); // Record the change time on pin 1
//filtering annoying duplicates, both temporal and identical consecutive values, omitting zeros, lets only 1
if (timePin1 != lasttimePin1 && statePin1 != laststatePin1 ) {
if ( statePin1 == 1) {
countererror1++; }
compareStates();
lasttimePin1=timePin1;
laststatePin1=statePin1;
void handlePin2Change() {
statePin2 = digitalRead(pin2);
timePin2 = millis(); // Record the change time on pin 2
if (timePin2 != lasttimePin2 && statePin2 != laststatePin2 ) {
if ( statePin2 == 1) {
countererror2++; }
compareStates();
lasttimePin2=timePin2;
laststatePin2=statePin2;
void compareStates() {
//checking the last pin, which is always 1 + checking if the pins have changed at least 1x to check the wrong direction
if (statePin2 == 1 && statePin1 == 1 && countererror1 > 0 && countererror2 > 0 ) {
//finding which direction it is facing
if (timePin2 > timePin1 ) {
counter--;
countererror1= 0;
countererror2= 0;
}else
counter++;
countererror2=0;
countererror1=0;
Serial.println(counter);
void loop() {
lcd.setCursor(0,0);
lcd.print("Counter:");
lcd.print(counter);
lcd.print(" ");
//check button pressed
buttoncheck = digitalRead(pin3);
if ((millis() - lastButtonPress) > 50) {
if (buttoncheck != buttonState) {
buttonState = buttoncheck;
if (buttonState == LOW) {
Serial.println("Button pressed!");
lcd.setCursor(0,1);
lcd.print("Button pressed!");
delay(300);
lcd.setCursor(0,1);
lcd.print(" ");
lastButtonPress = millis();
delay(1);
