Introduction: How to Connect a Nintendo Switch to Your Television.
About: I am a senior at Bowling Green State University
The advancement of technology is bringing forth new ways to entertain ourselves in society. Utilizing games systems for fun as well as function is a new way of life. The Nintendo Switch is a great console that gamers and casual players alike can enjoy! However some might not know how to connect this device to a television. This step by step tutorial will help you understand how to easily connect your Switch to your television.
Materials that will be needed:
1. A Nintendo Switch
2. A Nintendo Switch dock
3. Joy cons
4. An AC adapter
5. An HDMI cord
6. A television
Disclaimer - Presentations are intended for educational purposes only and do not replace independent professional judgment. Statements of fact and opinions expressed are those of the creator. The video provided within this demonstration is for convenience only. I do not sponsor, endorse or otherwise approve any of the equipment used. While every effort and care is taken in preparing the content of this site, Amir Griffin disclaims all warranties, express or implied, as to the accuracy of the information in any of the content. It also (to the extent permitted by law) shall not be liable for any losses or damages arising from the use of, or reliance on, the information on this demonstration. It is also not liable for any losses or damages arising from the use of, or reliance on this demonstration, or the internet generally.
Step 1:
Open the back cover of the Nintendo Switch Dock
Step 2:
Connect the USB plug from the Nintendo Switch AC adapter (model No. HAC-002) into the top terminal of the dock that is labeled "AC ADAPTER," then connect the other end of the AC adapter the AC port .Connect one end of the HDMI cable into the bottom terminal of the dock labeled "HDMI OUT," then connect the other end into an HDMI port on your television.
Step 3:
You are the going to close the back cover of your Switch.
Step 4:
This is what your Switch looks with the joycons attached.
Step 5:
You going to remove the joy-cons by holding the buttons on the back of each joy-cons and pulling them up. With the results being here.
Step 6:
Position the console so that the console screen faces in the same direction as the front panel on the dock, then insert the console into the dock.
Step 7:
Plug the ac adapter into a charging port.
Step 8:
Then turn on your tv, go to the correct HDMI channel and now you can play the Switch.
Step 9: Putting It All Together
