Introduction: How to Connect a Windows Laptop and IPhone to a Wireless Network
Introduction:
Forbes said in March that statistics show that high-speed internet is now available in almost eight out of ten homes in the United States. The world is becoming more dependent on technology, and it doesn’t seem to be slowing down anytime soon. The other statistic Forbes published is that every home normally has more than one device that can connect to the internet. These instructions will help any novice internet user to get their home fully connected to the internet by connecting it to the wi-fi router. Once you have read and followed these directions, you will be online and able to enjoy all of the favorites of the internet such as: help with homework, playing games, or even connecting to friends and family all across the world.
Description of the Equipment:
- Wi-fi modem – this is the wireless router that is connected to the router that comes from your internet service provider (ISP).
- A laptop computer running Windows 7 or higher – this is the device that is going to be connected to the wi-fi network wirelessly.
- Wi-fi access card – these are normally already installed in laptops. It captures the wi-fi signal and allows the computer to use the signal for internet.
- iPhone 4s or above – this is a smartphone from Apple. A smartphone is a phone that has the abilities of going online. A smartphone can also connect to a wi-fi connection to help the user not go over on their data plan, if applicable.
- Power cords – these apply power to the devices named above.
List of Materials:
- Make sure you have clean spaces in which you can move freely when you are working with electronics.
- Paper and pen may also be good, because you may need to write down information based on your ISP.
- User my need a power strip (surge protector) to allow many devices to be plugged in safely at the same time.
Step 1: Determining How to Connect
- If you are setting up wi-fi on your laptop, keep reading for next steps.
- If you are setting up using your iPhone on wi-fi, skip and continue at step 3.
Step 2: Connecting the Windows Laptop
Step 3: Connecting the IPhone
Step 4: Troubleshooting
- Is the modem’s lights illuminated like it shows on the ISP’s manual? If not, follow directions in ISP’s manual to troubleshoot those steps.
- Is the computer not getting internet by a wireless connection? If not, make sure you selected the right network. You may also check and make sure you typed in the right password if your network has a password. Hint: most network’s passwords are case-sensitive.
- Is your iPhone not connecting to the internet? Check and make sure you selected the right network or retry entering in the password to make sure you accidently didn’t type the password wrong. Remember that most network’s passwords are case-sensitive.
- If your wireless network going in and out of range? If so, you may be moving far enough away from the router where you will be out of range. Try moving closer to the router and see if that helps.
- What if my internet connection isn’t working? If that is the case, you will need to call the technical support team of your ISP. Below are the numbers I’ve gathered during online research to help you better in this process.
- AT&T (800) 331-0500
- Comcast (800) 934-6489
- EPB (423) 648-1372
- Charter (888) 438-2427
- WildBlue (855) 627-2554
- Time Warner (800) 892-4357
- Cox (877) 832-7658
- CenturyLink (800) 366-8201
- TDS Telecom (866) 571-6662
4 Comments
8 years ago on Introduction
Nice tutorial. Thanks for sharing.
Thank you :-)
Isn't the assumption that if you are reading this, you are connected to a network already?
Haha, yes... you are correct. However, I'm posting this for a class I'm currently in for one of my final grades. :-)
