Introduction: How to Consume a Simple Java Web Service From a C++(Legacy) & Java Application
Apache Tomcat(on WIndows7 in my case)
Apache Axis(on WIndows7 in my case)
GSoap(on Redhat running on Virtual Box in my case)
Video:
First , write a functionality which you want to be consumed by a JAVA/C++ application as a Web Service & save it as *.jws in your axis installation director(\Tomcat 7.0\webapps\axis). After this run the http://
EncryptDecrypt.jws
public class EncryptDecrypt {
public String encDec(String _inpDat){
String _outDat=new String();
int j=1;
if(_inpDat.charAt(0)!='#')
_outDat+="#";
j=0;
for(int i=j;i<_inpDat.length();i++)
_outDat+=_inpDat.charAt(0)=='#'?(char)((int)_inpDat.charAt(i)-1):(char)((int)_inpDat.charAt(i)+1);
return _outDat;
Secondly, we design the client application in JAVA/C++
JavaWebClient.java
import org.apache.axis.client.Call;
public class JavaWebClient {
public String main(String args) throws Exception {
String url="http://
Call data= new Call(url);
String val= (String)data.invoke("","encDec",new Object [] {args}); //encDec is the function name from EncryptDecrypt.jws
return val;
For C++ client you need to perform the following steps on the console:
wsdl2h -o EncryptDecrypt.h http://
soapcpp2 -i -C -I
Step 1: Create & Execute C++ App
Now, we will create Xmotif application.
Cclient.c
#include
#include
#include "soapEncryptDecryptSoapBindingProxy.h" // obtain the generated stub
#include "EncryptDecryptSoapBinding.nsmap"
#include
#include
void callWeb();
Widget text,text1;
main (int argc, char *argv[])
XtAppContext app;
Widget toplevel, button;
void my_callback(Widget, XtPointer, XtPointer);
XmString btn_text;
Arg args[2];
XtSetLanguageProc (NULL, NULL, NULL);
toplevel = XtVaOpenApplication (&app, "Web Client", NULL, 0, &argc, argv, NULL,
sessionShellWidgetClass, NULL);
Widget form=XtVaCreateManagedWidget("",xmFormWidgetClass,
toplevel,XmNrightAttachment,XmATTACH_FORM,XmNy,10,XmNwidth,447,XmNheight,587,XmNbackground,0xa1b6d6,NULL);
Widget firstLabel=XtVaCreateManagedWidget("",xmLabelWidgetClass,form,
XmNlabelString,XmStringCreateLocalized("Encrypt/Decrypt Web Service Client by Saurabh Saxena"),XmNbackground,0xc1ffff,XmNtopAttachment
,XmATTACH_FORM,XmNleftAttachment,XmATTACH_FORM,XmNrightAttachment,XmATTACH_FORM,NULL);
Widget Label=XtVaCreateManagedWidget("",xmLabelWidgetClass,form,XmNlabelString,XmStringCreateLocalized("Enter Text"),XmNbackground,0xc1ffcc,
XmNtopAttachment,XmATTACH_WIDGET,XmNtopWidget,firstLabel,XmNleftAttachment,XmATTACH_FORM,XmNwidth,75,XmNheight,29,NULL);
text=XtVaCreateManagedWidget("",xmTextWidgetClass,form,XmNleftAttachment,XmATTACH_WIDGET,XmNleftWidget,Label,XmNtopAttachment,
XmATTACH_WIDGET,XmNtopWidget,firstLabel,XmNwidth,75,XmNheight,29,XmNbackground,0xffffff,XmNeditable,TRUE,XmNcursorPositionVisible,
FALSE,XmNhighlightThickness,0,XmNshadowThickness,1,NULL);
button = XtVaCreateManagedWidget("",xmPushButtonWidgetClass,form,XmNtopAttachment,XmATTACH_WIDGET,XmNtopWidget,firstLabel,
XmNleftAttachment,XmATTACH_WIDGET,XmNleftWidget,text,XmNlabelString,XmStringCreateSimple("Click"),XmNheight,20,XmNwidth,40,NULL);
Widget Label2=XtVaCreateManagedWidget("",xmLabelWidgetClass,form,XmNlabelString,XmStringCreateLocalized("Output Text"),XmNbackground,
0xc1ffcc,XmNtopAttachment,XmATTACH_WIDGET,XmNtopWidget,Label,XmNleftAttachment,XmATTACH_FORM,XmNwidth,75,XmNheight,29,NULL);
text1=XtVaCreateManagedWidget("",xmTextWidgetClass,form,XmNleftAttachment,XmATTACH_WIDGET,XmNleftWidget,Label2,XmNtopAttachment,
XmATTACH_WIDGET,XmNtopWidget,text,XmNwidth,75,XmNheight,29,XmNbackground,0xffffff,XmNeditable,FALSE,XmNcursorPositionVisible,
FALSE,XmNhighlightThickness,0,XmNshadowThickness,1,NULL); XtAddCallback (button, XmNactivateCallback, my_callback, NULL); XtManageChild (button); XtRealizeWidget (toplevel);
XtAppMainLoop (app);}void my_callback (Widget w, XtPointer client_data, XtPointer call_data)
{ XmPushButtonCallbackStruct *cbs =(XmPushButtonCallbackStruct *) call_data; callWeb();
}void callWeb()
{ EncryptDecryptSoapBindingProxy service; std::string result;
if (service.encDec(XmTextGetString(text),result) == SOAP_OK)
std::cout << "Result" << result << std::endl;
char *cstr = new char[result.length() + 1];
strcpy(cstr, result.c_str());
XmTextSetString(text1,cstr);
delete [] cstr;
else
service.soap_stream_fault(std::cerr);
Compile the above code using the following command:
g++ -o Cclient Cclient.c soapC.cpp soapEncryptDecryptSoapBindingProxy.cpp -lgsoap++ -lXm -lXt -lX11
Run the Executable to access the functionality provided by Web Service.
